Fordite Steering Wheel
Topic author - Posts: 73
- First Name: Bill
- Last Name: Obier
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor, 1926 TT, 1913 Speedster (WIP)
- MTFCA Number: 28973
Looking for advice on the cleaning and preservation of original Fordite steering wheels.
- MTFCA Number: 4838
- MTFCI Number: 115
Re: Fordite Steering Wheel
Really can’t restore the surface finish as these composite Fordite can be in rough shape. Originals were heat pressed and had nice mold hard surface with a shine.
If real nice, then fine steel wool or super fine finish grit paper and work it to clean. Soap and water first to remove dirt and grime.
Now the clean Fordite will rub off on your hands, giving you brown uck, that gets worst with sweat or rain.
Tame that with good polish and wax. Repeat wax coating from time to time.
Or, spray with matt clear enamel, that holds for a good long time, then easy to strip and re-coat.
- Last Name: Page
- MTFCA Number: 28488
- Board Member Since: 2010
Here is a link to a discussion here on the Forum a few days ago.
Best regards, John Page, Australia.
search.php?keywords=Fordite
- Last Name: Page
That link didn't work as well as I wanted it to work. Sorry about that.
Here is a direct link to the previous discussion.
viewtopic.php?f=2&t=9279
- Last Name: Whelihan
- MTFCA Number: 30688
- Board Member Since: 2008
I have followed Dan's routine, and then use successive coats of semi-gloss water based poly. Seals up the Fordite and leaves it with a nice, but not too shiny finish.
- First Name: Bill
- Last Name: Obier
THANKS!!!
- First Name: Gary
- Last Name: Como
- MTFCA Number: 49625
When I restored mine, I wet sanded starting with 180 grit and worked my way to 1500 grit. Then applied a couple coats of butchers wax. I could'nt be happier with the results. (And no black hands when driving)
