Looking for Ford HCCT Serial Numbers
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Wed Jan 01, 2020 2:32 pm
As you may know, Ron Patterson and I are writing a book on the Hand Cranked Coil Tester (HCCT).
I am researching serial numbers on the Ford HCCT.
The Ford HCCT can be identified by the Part/Serial number stamped on the base (see photo below).
It may be on the right or left side.
We would like to know the serial number of your unit and if it is on the right or left side as viewed from the front.
A photo would be helpful but not necessary.
The book is nearly complete.
It is over 90 pages and has nearly 200 photos and illustrations.
Thanks for your help
Respectfully Submitted,
Be_Zero_Be
For every Absolute Model T Fact there are at least three exceptions
You never used to be older :shock:
dykker5502
First Name: Michael
Last Name: Deichmann
MTFCA Number: 29116
Re: Looking for Ford HCCT Serial Numbers
Post by dykker5502 » Wed Jan 01, 2020 2:51 pm
FWIW - my danish HCCT do not have any numbers or any markings at all, neither brassplates or holes after such.
Frontview:
Detail view of instrument face (all danish text - made by/delivered by HM = Helweg Mikkelsen, a major danish instrument/gauge maker.
Ford Model T 1914 Touring
ECCT, Strobospark, HCCT, Rebuilding coils
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Wed Jan 01, 2020 4:04 pm
Michael,
Is that a mark under the band on the coil box?
Be_Zero_Be
AndyClary
First Name: Andrew
Last Name: Clary
MTFCA Number: 24057
Post by AndyClary » Thu Jan 02, 2020 12:45 pm
Here is my hcct awaiting restoration. It has the same part number as your example. Facing the front it is on the left side of the base. It has a pulley on the back that looks like it’s never seen a belt. It came with a Weston meter. Thanks for the work at preserving this information.
Andy
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Thu Jan 02, 2020 1:06 pm
Andy,
That is an original Ford HCCT.
The Pulley on the back is unique to the Original Ford unit.
Thank you for your response to our request.
It is very helpful.
Be_Zero_Be
Dave S
First Name: David
Last Name: Simmering
MTFCA Number: 11531
MTFCI Number: 10138
Post by Dave S » Thu Jan 02, 2020 1:11 pm
Mine is the same number shown on the first picture. It is stamped on the right side.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Thu Jan 02, 2020 2:09 pm
Thank you Dave.
Be_Zero_Be
david_dewey
First Name: David
Last Name: Dewey
MTFCI Number: 19936
Post by david_dewey » Fri Jan 03, 2020 2:58 am
With multiple responses indicating having the same "serial" number, is it possible that is a Ford Tool Number?
T'ake care,
David Dewey
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Fri Jan 03, 2020 7:36 am
18Z245 is the tool number listed in Ford documents.
The 18Z245N180 is hand stamped on the base.
The "N180 suffix is not consistent with other cast-in part numbers.
For example, 18Z245 B is cast into the spark ring.
There are no known drawings in the Ford archives for the 18Z245 tool.
Be_Zero_Be
Dom Denio
First Name: Dom
Last Name: Denio
MTFCA Number: 27167
MTFCI Number: 20405
Post by Dom Denio » Fri Jan 03, 2020 7:55 am
Bob,
The red circle in your earlier post shows an outline shadow on the coil holder box that looks similar in shape to the KR Wilson decal pictured below.
Thanks to you and Ron for your support of our hobby members,
Dom Denio
KR Wilson Decal.docx
(21.48 KiB) Downloaded 49 times
keen25
First Name: Eric
Last Name: Keenan
Post by keen25 » Fri Jan 03, 2020 10:51 am
Hi, Will the book have a how to section on the restoration, calibration and maintenance of the HCCT? I am sorry about being a pain. Thank you for your work on this.
Ron Patterson
First Name: Ronald
Last Name: Patterson
Post by Ron Patterson » Fri Jan 03, 2020 11:15 am
YES
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Fri Jan 03, 2020 11:45 am
Dom,
They are not the same.
Be_Zero_Be
Les Burg
First Name: Les
Last Name: Burg
MTFCA Number: 7463
Post by Les Burg » Fri Jan 03, 2020 1:14 pm
Bob, I can't find any stamped numbers on either side, but it has the 18Z245 cast into the backside of the mainframe.
It has been painted sometime in its life and that may be hiding the hand-stamped markings?
Hope this helps.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Fri Jan 03, 2020 1:35 pm
Les,
Could you post a photo of the cast "18Z245"?
Thanks,
Bob
Be_Zero_Be
GG Gregory
First Name: GG
Last Name: Gregory
Post by GG Gregory » Fri Jan 03, 2020 4:28 pm
I want a copy of the book ! I have a KR WILSON and a Allen that I'd like to get going.
Les Burg
First Name: Les
Last Name: Burg
MTFCA Number: 7463
Post by Les Burg » Fri Jan 03, 2020 6:00 pm
Bob, I meant to say back of "spark ring" There something cast in the mainframe, near the bottom of it I will take the flywheel off and see if I can make it out, it is really faint. Hope this helps
BHarper
First Name: Bill
Last Name: Harper
MTFCA Number: 5414
Post by BHarper » Fri Jan 03, 2020 8:24 pm
I have one which is somewhat buried at this moment. I will dig my way to it tomorrow and look for a number.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Sat Jan 04, 2020 12:49 am
Les,
Thank you for the photo. It does help.
Bill,
Thanks for taking the time to help us.
Be_Zero_Be
Les Burg
First Name: Les
Last Name: Burg
MTFCA Number: 7463
Post by Les Burg » Sat Jan 04, 2020 2:56 pm
Bob, I disassembled it in order to get a view of the mainframe and found what I think is a pattern number which is very distorted, you can see the outline of the tag and the fasteners holding it to the pattern (I’m not good at taken pictures) the only visible number is “18” on the left side and maybe a “4” on the right side.
I did strip the paint on both sides and still, no hand stamped numbers.
Sorry I couldn't be of more help.
I know it doesn't matter in dating it, but it does have a “DB” flywheel on it.
Les
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Sat Jan 04, 2020 3:33 pm
Les,
Thank you for the photos.
The lack of a hand stamped number on the side of the base indicates that this is probably one of the early Fairbanks-Morse copies.
Does this one have a pulley on the back of the flywheel?
Be_Zero_Be
Les Burg
First Name: Les
Last Name: Burg
MTFCA Number: 7463
Post by Les Burg » Sat Jan 04, 2020 5:08 pm
Bob, yes it has the pulley.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Sat Jan 04, 2020 5:47 pm
If it has a pulley - It's a most likely a Ford unit.
Be_Zero_Be
BHarper
First Name: Bill
Last Name: Harper
MTFCA Number: 5414
Post by BHarper » Sat Jan 04, 2020 7:47 pm
Well, I did make my way out to where my HCCT is currently in storage. I could not make out any numbers on either side of the base of the machine. It has been painted and that may be obscuring any markings. Sorry.
I did take a picture of it. I hope this is of some use. Thank you gentlemen for undertaking the project of writing a book on the HCCT, Bill
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Sun Jan 05, 2020 2:34 am
Bill,
Thanks for taking the time to help.
That looks like Service Station Equipment Company (SSECO) unit.
Bob
Be_Zero_Be
dykker5502
First Name: Michael
MTFCA Number: 29116
Post by dykker5502 » Sun Jan 05, 2020 11:13 am
HA! You have just found the danish manufacturer/dealers nameplate! I havn't noticed that before!
No numbers or identification. I've tried to find the logo:
W. Løwener_Logo.jpg (24.73 KiB) Viewed 1928 times
The figure in the middle is a lion in front of what probably back then was their main product - a lathe.
The delivered all the Ford special tools to the dealers and shops in Denmark and possibly the rest of Scandinavia.
They are still in the business, now with an updated logo:
W. Løwener_Nyt_Logo.jpg (12.77 KiB) Viewed 1928 times
https://loewener.dk/en/
Dropacent
Last Name: Morsher
Post by Dropacent » Sun Jan 05, 2020 1:36 pm
I’m hoping the person who bought my HCCT responds to this. It is probably the nicest original machine I’ve seen personally, and it was a joy to be the caretaker for a long time, I believe it is a Fairbanks-Morse unit from what I have read over the years. It is very book worthy, IMHO Thanks for these efforts. Might you fellows know where these particular units were made and sold? There is a beautiful old Fairbanks building in the south side of Chicago, and always wondered if connected. I know they made and sold a lot of stuff. Thanks!
Ron Patterson
First Name: Ronald
Post by Ron Patterson » Sun Jan 05, 2020 1:39 pm
Michael
Great find and thank you for bringing it to our attention.
That should make a good inclusion to the Danish section of the HCCT Manual.
Ron Patterson
Jsteele
First Name: John P.
Last Name: Steele
MTFCA Number: 374
MTFCI Number: 137
Post by Jsteele » Sun Jan 05, 2020 6:00 pm
Bob your suspicions were correct. Sorry for the poor picture that posted upside down. It does right itself when clicked on. I started to take it out in the sunlight but after about 15 feet my back said something different. :) 18Z245N180
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Sun Jan 05, 2020 7:31 pm
John,
That confirms our suspicion that "N180" is not a serial number.
We have found at least five occurrences of "N180".
Thank you for your help.
Be_Zero_Be
keen25
First Name: Eric
Last Name: Keenan
Post by keen25 » Mon Jan 06, 2020 6:56 am
I am curious, did he early HCCT manufactures or Ford patent their devices?
Ron Patterson
First Name: Ronald
Post by Ron Patterson » Mon Jan 06, 2020 8:15 am
Eric
Be patient, the complete story of the genesis, evolution and derivations of the HCCT will be told in the upcoming Model T Ford Club of America publication entitled "HCCT Handbook" that will be available soon.
It will be 90+ pages of information about early HCCT development, the story of how Ford made the first commercially available HCCT's and how to identify, including photos, of the many different types of HCCT's made by other manufacturers. Restoration details and parts sources.
Probably more details than you ever wanted to now about the HCCT?
CVSJCS
First Name: JEFF
Last Name: STAHL
Post by CVSJCS » Thu Jan 09, 2020 3:02 pm
looking for more numbers
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Thu Jan 09, 2020 4:32 pm
The number would be stamped on the side of the base like the first photo in this thread.
Be_Zero_Be
CVSJCS
First Name: JEFF
Last Name: STAHL
Post by CVSJCS » Wed Jan 22, 2020 5:39 pm
I use a flat file to scrape and didn't see any numbers of either side of the base?!?!?!
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Thu Jan 23, 2020 3:22 pm
Jeff,
This could be one of the early Fairbanks copies.
They were produced without the hand stamped part numbers.
Be_Zero_Be
J1MGOLDEN
Last Name: Golden
MTFCA Number: 14294
MTFCI Number: 13562
Post by J1MGOLDEN » Sun Jan 26, 2020 7:48 am
My HCCT has the pulley, like Les has shown in his photos, and all the numbers cast in the frame, pulley, and spark ring, but no serial number on the side.
The heavier spark ring on Bill's unit is a giveaway that it is a Service Station Equipment Company HCCT.
My SSE spark ring was brass with 16 deep grooves cut into it.
The one Les has could be an earlier unit, or have a replacement "Home Built" spark ring, or have it on wrong side out.
Over the years, many people have made the mistake of using the spark ring for a carry handle and ended up with a two piece spark ring.
The brass is kind of thin where the bolts go through and make an easy break area there,
namdc3
First Name: Nikolaus
Last Name: Martin
MTFCA Number: 32342
MTFCI Number: 23512
Post by namdc3 » Wed Jan 29, 2020 9:48 pm
Am I to gather from the above that the part number and N180 in the side of the base and a pulley on the back does not indicate an original Ford unit since N180 isn’t evidently a SN? Ron used to post that Ford units had “SNxxxx” hand stamped in the base. I assume it’s in this location, as well? In other words, these N180 units are early outsourced ones, and it has to have “SNxxxx” to be a Ford?
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Wed Jan 29, 2020 10:59 pm
Original Ford HCCTs have 18Z245N180 hand stamped on the side of the base.
18Z245-A, -B, -C, etc. is cast into the various parts of the HCCT (base, spark ring, pulley, etc.) on Ford and some non-Ford units.
It's all explained in the book.
Be_Zero_Be
namdc3
Last Name: Martin
MTFCA Number: 32342
MTFCI Number: 23512
Post by namdc3 » Wed Jan 29, 2020 11:02 pm
Ok, so no "SNxxxx". How about the pulley on the back - I gather all Ford ones had it, but some early outsourced ones did, too? (and, yes, I will be buying a book).
To be even more specific in your statement, do you mean ONLY Ford units had the number stamped in the base? I.e., all outsourced units (F-M) did not? I.e., an original stamping there says it for sure is Ford?
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Thu Jan 30, 2020 12:23 am
To the best of my knowledge, only the original Ford produced units had the hand stamped 18Z245N180.
Be_Zero_Be
namdc3
Last Name: Martin
MTFCA Number: 32342
MTFCI Number: 23512
Post by namdc3 » Thu Jan 30, 2020 9:53 am
Bob, thank you for this information. If you could tolerate one more question, what is the story on some units having the pointer/electrode straight opposite the crank handle and others having it at 90 degrees to the crank handle? I stole one photo from above (on a 18Z245N180 stamped unit) and the other from this post (http://www.mtfca.com/discus/messages/82 ... 1538095738) (also a 18Z245N180 stamped unit).
namdc3
Last Name: Martin
MTFCA Number: 32342
MTFCI Number: 23512
Post by namdc3 » Thu Jan 30, 2020 6:38 pm
I understand now that those are two pieces with individual set screws. Handle can be removed when operating with pulley. Makes sense.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Fri Jan 31, 2020 11:02 pm
namdc3 is correct.
That's an observation I did not make.
Be_Zero_Be
namdc3
Last Name: Martin
MTFCA Number: 32342
MTFCI Number: 23512
Post by namdc3 » Sat Feb 01, 2020 12:01 pm
It’s interesting that the manual doesn’t mention the pulley. I wonder if this manual is slightly later after discontinuation of the pulley, or if the pulley was actually used by Ford to qualify the HCCT itself prior to its use. I have no idea other than guesses.
http://www.cimorelli.com/mtdl/unknown-y ... d-hcct.pdf
