Need Dummy axle for cantrell miller sleeve puller
Topic author - Posts: 161
- First Name: Warren
- Last Name: Webb
I need a dummy axle for the Cantrell Miller sleeve puller so I can remove sleeves out of a single housing. Someone told me that someone on here reproduced these.
- First Name: Joseph
- Last Name: M
- MTFCA Number: 0
Re: Need Dummy axle for cantrell miller sleeve puller
I believe that it was Scott Conger that had made some. If you have an old won-out axle and a couple of 2" OD washers, you can make one:
I had welded the washers together and than welded them to the cut off portion of the old worn out axle.
