Need Dummy axle for cantrell miller sleeve puller
23ford
First Name: Warren
Last Name: Webb
Post by 23ford » Sat Jan 04, 2020 3:36 pm
I need a dummy axle for the Cantrell Miller sleeve puller so I can remove sleeves out of a single housing. Someone told me that someone on here reproduced these. :D
Pep C Strebeck
First Name: Joseph
Last Name: M
MTFCA Number: 0
Re: Need Dummy axle for cantrell miller sleeve puller
Post by Pep C Strebeck » Sat Jan 04, 2020 4:25 pm
I believe that it was Scott Conger that had made some. If you have an old won-out axle and a couple of 2" OD washers, you can make one:
I had welded the washers together and than welded them to the cut off portion of the old worn out axle.
