26 gas tank
Posted: Thu Jan 09, 2020 4:51 pm
by Ed Donnelly
Need a source for 26 gas tank weld in inlet fitting. I'm replacing several anf need help.
Re: 26 gas tank
Posted: Thu Jan 09, 2020 5:15 pm
by Humblej
No new sources, you will have to salvage from another tank.
Re: 26 gas tank
Posted: Thu Jan 09, 2020 6:56 pm
by jbond
I got a used but excellent 27 tank from :
http://bobsantiqueautoparts.com/
Wash out a few dead mice and it was good to go.
Re: 26 gas tank
Posted: Thu Jan 09, 2020 10:17 pm
by Ed Donnelly
Well the suppliers are getting newtanks for 09's -27 from somebody. I'm sure mfg. Overseas, but the weld in fittings are what I'm needing.
Re: 26 gas tank
Posted: Thu Jan 09, 2020 10:35 pm
by Ruxstel24
I have a pretty decent original tank....
Re: 26 gas tank
Posted: Thu Jan 09, 2020 10:36 pm
by RajoRacer
Actually Ed, the gas tanks are made in the U.S. - bad news is no one is reproducing '26-'27 cowl tanks !
Re: 26 gas tank
Posted: Thu Jan 09, 2020 10:38 pm
by John.Zibell
As far as I know, no one is making 26/27 cowl fuel tanks. So no new production of the fitting the sediment bowl goes into. You could salvage one from a bad tank, or fabricate your own. The thread is 1/2 inch pipe thread. You would have to make up some type of collar to fit the pipe thread piece to the tank. The metal is thin, so the part would have to be soldered or brazed to the tank.
Re: 26 gas tank
Posted: Fri Jan 10, 2020 8:53 am
by Ed Donnelly
Hey Steve, who is the manufacturer of the 25 and earlier tanks? They too will work and yes they are soldered.
Re: 26 gas tank
Posted: Fri Jan 10, 2020 10:42 am
by RajoRacer
I don't have his name but he's in Arkansas, I believe - Donnie Brown knows him & he's on here - maybe he can supply it.
Re: 26 gas tank
Posted: Fri Jan 10, 2020 10:47 am
by TRDxB2
I don't know if there are differences in the '26 gas tank inlet looks like but this is from an earlier tank. It was soldered in. Something I can part with.
Re: 26 gas tank
Posted: Sat Jan 11, 2020 11:31 am
by Ed Donnelly
Thank, but I'm looking for a quantity supplier so I may do local repairs.
