Why won't my 1915 engine start unless I tow (bump-start) the car.
Topic author - Posts: 512
- Last Name: California
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1912 Warren Speedster
- MTFCA Number: 50392
Hello fellow Model T-ers,
I just put a brand new reproduction New Day timer (from Spokane, WA) on my 15 Touring. Despite wearing myself out cranking the engine 30 or more times it won't start that way. The gas is on. I prime it by giving it a few cranks with the key off and the choke wire pulled before turning the key to battery. I hear a strong buzz from all 4 coils. The mixture knob was set just yesterday, with engine running, by a respected Model T-er and the car runs great once it starts. There is no smell of fuel when I crank it 30+ times. It has half a tank of gas. The gas valve under the tank is in the on position. I try enriching the mixture but this doesn't help. But, ONCE I "TOW-START" IT IT RUNS FINE.
Would any of you know what might be causing this problem and/or perhaps a solution? I mean, short of installing an electric starter. I will be going on the Fallbrook Tour this coming Sunday and Monday and sure would like to have this problem solved by then. I will appreciate any advice you may offer.
Thank you,
Mr Sore Arm
Thank you,
Mr Sore Arm
- First Name: Andrew
- Last Name: Clary
- MTFCA Number: 24057
Re: Why won't my 1915 engine start unless I tow (bump-start) the car.
Sometimes we get carried away adjusting the carb. Try opening the adjustment a quarter turn. While running, a little lean is ok but make make a stem winder hard to start. Also double check that the timing isn't a little retarded. Give me a call if you need to.
Andy
Andy
- MTFCA Number: 52564
How new is the engine and how much run time has it had if fresh? Have you checked the timing? You could have the adjustment open too much. Close it down and re-open 1-1/4 to 1-1/2 turns open. Have you checked ACTUAL gas flow to carb? Could be vacuum leak between the carb and intake or intake and block.
1920 Dodge touring
1920 Dodge touring
- MTFCA Number: 14972
- MTFCI Number: 15411
Ditto what Mark referred to - I'd suspect a compression or vacuum issue.
- First Name: Gene
- Last Name: Carrothers
- MTFCA Number: 22905
- MTFCI Number: 23068
Since you changed to a different timer I would be suspect of the timing. Check that again. You said the car runs fine once it gets started so I would rule out gas supply is the problem. The carb setting could be suspect.... My "12 hand crank car always starts great EXCEPT if it gets flooded I then have shut off the fuel valve and crank it several times wide open throttle to clear it out. if you've cranked yours a lot this is something to try. You should be able to feel the compression as you crank but could check for a leak when you have it running with a can of aerosol.
Good Luck and see you in Fallbrook.
1912 Torpedo Roadster
- Last Name: Osterman
Had you installed the intake and exhaust manifolds recently? Just curious if you have a leak. Also check the gas in your carb by letting some out the bottom into a white container like a coffee cup. Look at what comes out.
I would start with setting the timing with the #1 spark plug out watching for piston rise on compression and having the spark plug fire a little after top dead center with the spark lever fully retarded.
Then close the carburetor needle down till it seats and open it around a turn and a half.
All you need is properly timed spark, compression and gas.
When installing a new timer you need to check the length of the timing rod. It can vary from one brand timer to another. Check to see when number 1 fires. Then turn the crank until it just begins to buzz. The pin through the front of the crankshaft which holds the crank when you crank the car should be just below the 3:00 position when the lever is all the way retarded. This would be looking toward the pulley from the front of the car. you might need to bend the rod to get it into this position. Be sure to remove the rod from the timer before you try to bend it.
- Last Name: Dufault
- MTFCA Number: 303
Steve,
My '15 floods when I choke it.
Granted, the float may be incorrectly adjusted, but for the most part, without choking...throttle down about 3-4 notches, timer down one notch, 4 out of 5 times it starts and runs by the third 1/4 pull.
Just for grins and giggles....try starting without choking and see what happens by the 5th 1/4 pull.
- MTFCA Number: 16175
- MTFCI Number: 14758
This may lot be the source of the problem, but you may as well eliminate the possibility.
http://dauntlessgeezer.com/DG97.html
- First Name: CHARLIE
- Last Name: BRANCA
- MTFCA Number: 28967
- Board Member Since: 2010
First off we need to know the engines age/condition. Second it's not been mentioned if this started with the timer change. I'm assuming it didn't. The faster cranking speed you get from towing is a bit telling. Leads me to think about low compression. You apparently have fuel and ignition since it starts/runs well after a tow.
I believe northsouth had a broken crankshaft last year and the engine was rebuilt shortly thereafter. However he did go on at least one tour since then so it should be broken in by now. Perhaps it has something to do with the colder weather. That would make the engine harder to crank and also need to be just a bit richer fuel mixture to get started. If after you check the timing, SteveJelf has linked you to a very good description of how to do this. If it is still hard to start, try jacking up a rear wheel and chock the front wheels. Leave the parking lever in the neutral position. This will relieve the drag caused by the clutch disks and make cranking easier.
Thank you everyone. I have the car parked outside my kitchen door, hood off, and am working through all of your generous advice.
I'm much obliged to you,
-Grateful Sore Arm
-Grateful Sore Arm
Hello Charlie B.
In answer to your question, yes, it did start with the new timer installed. But, it took 30+ cranks and a qualified Model T-er at the steering wheel while I was ruining my arm up front. And then just barely.
Hello Charlie B.
- First Name: Terry
- Last Name: Bond
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Chassis
- MTFCI Number: 15718
A clue for me is the fact you are not smelling gas. It should be easy to flood, and just a couple of turns on the crank with the choke pulled out should result is gas squirting out the overflow hole on the carb. I'll bet you are using a Holley NH and it has one of those after-market fuel inlets where the old fashioned needle valve was replaced with a grose-jet ball bearing type shutoff. The ball tends to stick in the seat preventing gas flow. Just the opposite can occur where a tiny spec of dirt prevents it from totally seating when the bowl is full and gas runs out all over the place.
If you are towing the car to start it, you may be jarring the ball bearing loose and that's what lets it start that way. Just another thought from someone who prefers the old fashioned needle valve.
Terry
Terry
Hello Steve Jelf,
The Timer Adjustment Link that you provided is helpful. Thank you. http://dauntlessgeezer.com/DG97.html
However, I am confused as to the orientation of point-of-view when it instructs me to "rotate the timer clockwise, then back, then clockwise again". Would this be from the point-of-view of the driver or from the guy cranking the engine?
Smiles,
Steven Chase
(323) 497-0601
Smiles,
Steven Chase
(323) 497-0601
The point of view is looking from the front of the car by the radiator toward the timer. Clockwise would move the top where the rod is connected toward the steering column and counterclockwise away from the steering column. Another thing to check is that none of the wires of the clips on the end of the wires touch anything which is grounded while the timer is rotated.
Thanks Norm, This is helpful. But it's got me beat.
I will be taking the car down to Ramona, CA on Thursday to let Tony Balkor take a look at it.
Smiles,
Steven
Smiles,
Steven
- MTFCA Number: 30701
- MTFCI Number: 24033
Steve C.--- this sooo smacks almost identical to what my former '15 was like. When I bought it, I was told the engine was completely rebuilt. I even talked to the previous owner to my previous owner about it, he was like 92 y.o. then, said he paid a guy from a "racing shop" big bucks to have it rebuilt. Frankly, from what me and Joe Bell discovered after, like you, I took it to him to figure out, it appeared as though the poor old fella was ripped off by it just being cleaned and painted. If indeed it was rebuilt, it was F--d up big time. Mis matched rods, plenty of technical things that now I can't even remember. Oh, I was able to get it to start after maybe 40 cranks, then 10 miles down the road it would overheat. We found "things" what I would say weren't "in alignment" inside, crap I can't remember. Anyway a smart guy like Joe figured out. Cracked but JB welded block inside, etc. Put in an entirely new engine that
started giving COLD free starts with just priming. Of course, no overheating! Ran like a top. Then I sold it! Shoulda kept it.
So what I'm getting at is, since at this point you didn't say if you checked compression at least, is maybe you just have a plain old tired engine. Or as others alluded to, maybe you have an intake leak somewhere. Or both. Any way, good luck, and keep us posted.
- First Name: Kenneth
- Last Name: DeLong
With a friend cranking hold your hand over the air inlet of the carb. You should get a strong suction.Just pulling the choke might not do so use your hand.Are your spark plugs wet with gas?? If not before you reinstall the plugs put a little gas in each cyl then replace the plugs and try it. Bud.
Tony Balkor to the rescue.
- Last Name: Golden
- MTFCA Number: 14294
- MTFCI Number: 13562
The most common cause for me has been the low compression made worse by letting all the oil drain off the cylinder walls between use.
The next problem is an accurate measurement of the compression has to be done by a screw in gauge to capture all the pressure for an accurate reading. That is easily over come with a modern compression gauge and a 14 mm to 1/4th inch spark plug adapter.
The most accurate area of those gauges is the middle third area which is about 150, as most gauges go to 300 pounds now.
That requires a gauge change to one with a 100 pound max pressure reading, as most Model T engines will have a compression between 45 and 55 pounds and 50 is right in the center of the gauge. Any pressure gauge will work and those used on orchard sprayers are the easiest to find. Most are made in China now, but they usually work. The larger dials are easier to read too.
I have often had to remove two spark plugs and pour in a shot glass full of engine oil to raise the suction capability of the pistons. Then add a shot glass full of gas to the cylinders and replace the spark plugs. Removing either 1 and 4 or 2 and 3 works the best.
That will usually let the engine turn fast enough to suck in some gas on the other two cylinders and run on all 4 of them.
If that don't help leave two of them out and the engine will turn over faster. Stop after a minutes running, replace the other two plugs and the engine will start right up again.
This system also works well for a newly rebuilt engine that does not want to turn over at all.
- First Name: Tony
- Last Name: Bowker
- MTFCA Number: 32
I looked it over and decided the following.
1. The plugs were dry and sooty even on full choke
2. Lots of suck at carb inlet
3. Timing Is rather restarted. The lever is at nine o’clock at top dead center. I’ve seen this previously when switching from roller timers to the carbon brush version.
4. We pulled the NH carb apart and all looks good, the needle could do with sharpening but the shut off needle looks fine and the float is a fraction less than 1/4” from the top.
5. We did a compression check. It’s hard with only a hand crank but it appeared to be 25-35 pounds.
6. All the plugs were very sooty.
I put raw gas in both #1 and then #2 plugs with no results. When I pulled the plugs there was a small pop When the plug sparked and the fuel burnt. No explosion. So we decided over lunch to pull the head The valves all looked very sooty. So we ground in all eight plugs, they only needed fine paste and most came with a nice grey line with just one application.
Then I asked why did Steve change the timer, “because the other one fell apart and there was HUGH backfire which blew off the preheated”.
So there it was, soot everywhere from backfire. After we replaced the head, new gasket etc it started on the fifth pull. The timing lever has to be at nine pm and the mixture needed to be at about one turn. That’s probably caused by the poor needle shape and Steve will have to shorten the timing rod but it should be OK for the weekend tour.
Tony Bowker
La Mesa, California
La Mesa, California
Great!
1920 Dodge touring
1920 Dodge touring
Very nice. I would reset the timing right away. It doesn't take long.
- Last Name: DeLong
Glad to hear it"s started and running but i can"t understand a lot of suction and dry spark plugs and with questionable valves? I wonder how dirty the engine is in the valve chamber? Needing that much advance to start,that sounds like a lot even on a mag start? Is the spark rod over or under the water pipe? Bud.
- Last Name: Tannehill
- MTFCA Number: 49460
I believe he may have the wrong size advance rod or not contoured to the appropriate bends for the commentator to be correctly retarded. Jelf’s video on timing is a simple & great example to follow when setting the timing and crank placement.
Hopefully it will be that simple. Tony great job of triage and getting it running.
Steve hope you don’t mind me providing the link.
http://www.dauntlessgeezer.com/DG97.html
- First Name: Tony
- Last Name: Bowker
- MTFCA Number: 32
Bud, the control rod goes Under RHD water pipe.
As I stated, I have seen these differences of rod length for different styles of timers previously.
Tony Bowker
La Mesa, California
La Mesa, California
Tony
it's nice that you guys lent a helping hand. As you implied, changing brands of timers is not a "one size fits all" situation. All that soot is undoubtedly from burning fuel far too late in the cycle to create an explosion. I've seen it numerous times. There often isn't even a detectable "pop" when it ignites. The first 10 words of the OP's description should have been the only clue needed to diagnose this thing.
The remarkable lack of knowledge in the hobby of how a T engine is timed is why I will NOT crank cars on tours for folks I do not know. One of the last tours I ran, several people tried to goad me into helping a fellow with a low battery on a starter car. The next bruiser in line intended to shame me and promptly got a badly banged wrist for his heroics.
Kudos for getting him back on the road.
NH Full Flow Float Valves
- First Name: Gene
Thanks to Tony for his help his expert Help!
I agree with Steve J and Scott C, It should be a 5 minute job to bend and set the timer rod to the correct timing position. Once set no one will have to remember to place the spark lever to some off standard position.
Did someone say this is a RHD car??
THANK YOU TONY BOWKER.
Your persistence has put the leader of our Fallbrook Tour back on the road.
See you all at the Pala Mesa Resort early Sunday morning.
Steven Chase (Mr "Recovering" Sore Arm)
...and father Lee
...and father Lee
- First Name: Gene
Hey Steven, Maybe that's exactly why Tony was given the Rosenthal Award last year! I bet your not the only guy he has helped..
Tony is a very helpful friend. He is ready to help either at home or on the road. On many tours, you will see him, hair messed up and clothes dirty because he was under someone's car helping them with it. I'm very glad that he won the Rosenthal award. He deserved it for many years, but finally received it.
