nh carb needle and seat
Posted: Fri Jan 17, 2020 10:34 am
by bobt
Does anyone know a part number for a NH carb viton tipped needle and seat? thanks, bobt
Re: nh carb needle and seat
Posted: Fri Jan 17, 2020 11:02 am
The Part Number at regular suppliers is: 6212
That part is made with an orifice that is smaller than original, by a sizeable margin. It is fine for driving where high speeds are not sustained, or long hard hills are encountered. If either of those two conditions will be met by you, then you may want a version of that valve which has the correct sized orifice and is designed to flow a larger amount of fuel, quicker, to avoid fuel starvation. See: https://www.mtfca.com/phpBB3/viewtopic. ... low#p70695
