TT REAR AXLE AUX TRANSMISSION ID
Posted: Sat Jan 25, 2020 12:54 pm
by StanHowe
Anybody know what this is?? It's on a C Cab TT a guy in Billings is getting ready to sell.
2020 1 25 tt truck
It's not mine, I can probably get some more info but I think at this point he just wants to know what this trans is. I don't recall every seeing one like it.
Re: TT REAR AXLE AUX TRANSMISSION ID
Posted: Sat Jan 25, 2020 2:46 pm
Stan
Right its not a Lincoln brand TT accessory.
fuller trans. TT REAR AXLE AUX TRANSMISSION ID
Posted: Sat Jan 25, 2020 2:51 pm
by Dropacent
It’s not a lincoln, as I have one on my Tt. I believe it’s a Fuller brand, made in Kalamazoo. Not 100% sure , but an educated guess. I had one 20 years ago, and was able to remachine it a bit to make it an overdrive. I’m starting to forget more than i remember.
Fuller & son TT REAR AXLE AUX TRANSMISSION ID
Posted: Sat Jan 25, 2020 3:00 pm
by Dropacent
Posted: Sat Jan 25, 2020 3:01 pm
Right on Tim, very educated guess.
June 1925 Ford Dealer and Owner
Posted: Sat Jan 25, 2020 3:33 pm
by Dropacent
That’s a beautiful ad, Dan, thanks!
Posted: Sat Jan 25, 2020 3:35 pm
by StanHowe
Thanks, I am always amazed at the accessories they made for Fords and the knowledge of them on this forum!!
Posted: Sat Jan 25, 2020 3:54 pm
by HPetrino
Neat gizmo. Since it's for a TT, I would imagine it's a direct and over, but it doesn't say that anywhere I can find. Does anybody know for sure?
Posted: Sat Jan 25, 2020 4:38 pm
by Dropacent
Yes, I know for sure they were under and direct. Very few original TT transmissions were OD. Pulling power is what was needed back then. I’m recalling now the one I had was in pretty poor shape. In my opinion, they were not built very stout compared to other brands. Surprising because the fuller company made a whole car before they shifted( pun) to the transmission line. They continued building transmissions way after the model T and A days, so they must have been reliable. Perhaps the one example I had might have had a million hard miles on it. That’s one reason I remade it as an overdrive unit. It was a challenge but worthwhile.
Posted: Sat Jan 25, 2020 4:43 pm
by Dropacent
If you read the advert., you just cut the torque tube, the original driveshaft passes right through the unit. Also, no neutral, another good feature.
Posted: Sat Jan 25, 2020 6:10 pm
by StanHowe
Fuller made a ten speed for big trucks. A lot of them ended up in International Diesels. At one point 60 years ago I was working for Northern Tank Lines hauling crude oil out of the Medora, North Dakota oil production treater sites. Several of the old worn out Kenworths had ten speed Fullers in them along with a two speed Eaton rear end or a Brownie aux trans. You could get out and walk around it and check your tires coming up the hills.
