Question, what is the clearance of the transmission shaft to brake drum bushings?
Posted: Sat Jan 25, 2020 5:14 pm
by lorenzo26
Question, what is the clearance the transmission shaft to brake drum bushings?
Re: what is the clearance the transmission shaft to brake drum bushings?
Posted: Sat Jan 25, 2020 6:17 pm
by Scott_Conger
You would be fine with .004.
As important or even more important is the TIR of the output shaft after bolting onto the brake drum. You can have proper clearance on bushings, but if those bushings are not dead nuts, you will have more runout than the 4th main can handle.
Posted: Sat Jan 25, 2020 8:03 pm
by lorenzo26
Thank u Scott - What is the term[dead nuts ?] and [TIR ]T= total ? I? R =run out? sorry I'm not familiar thank you Lorenzo
Posted: Sat Jan 25, 2020 9:23 pm
by Scott_Conger
Total Indicated Runout
The maximum excursion from a "0" point
Re: Question, what is the clearance of the transmission shaft to brake drum bushings?
Posted: Sun Jan 26, 2020 12:08 pm
by Original Smith
I believe that information is in the service book.
