Stromberg/Lathe Fun
Posted: Sun Jan 26, 2020 4:33 pm
I am definitly not the first to do this, but it has been a fun exercise in figuring things out, as well as being a satisfying turning exercise, and thought that somewhere some Walter Mitty of the Machine Shop would enjoy seeing. I also discovered during the process, that though the parts are simple, there are a couple of not-so-obvious traps in getting this done. The seat that was replaced is on top, and the rest is self-explanitory. Throttle shaft, choke shaft and bushings for the body are next. One thing I can tell you, and it is no surprise, is that there is no easy way to do this work in any amount of time without making lots of multiples of parts at a sitting, for future use, as the setup takes all your time. The parts are simply a happy result of your set up effort, and almost anti-climatic when all is said and done. The great and interesting thing about machine work is that if the set-up is correct, the results are pretty much a forgone conclusion.
And yes, the camera severely distorted things...the two fittings are exactly the same size in real life.
My hat is off to Stan and others who can make this into a money making enterprise. Tooling isn't cheap, fixtures must be made, and a lot of time gets spent for little to show if you're doing just one-off work.
