Anyone have 8 and/or 10 hp Model A flywheel weight?
Posted: Thu May 29, 2025 9:28 am
				I’m looking for the weight of both the 16 inch (primarily 10 hp A) and 20 inch (8 hp) flywheel.  If anyone has a n A motor apart I would appreciate the weight and measurement of the flywheel.  If the crank is still attached, the weight of both is good too.
The Model C flywheel should be the same as the 10 hp A, but if anyone has the “C” flywheel by all means please weigh and post that weight too.
Thank you in advance. I’ll post results and other info as we learn more.
Cheers,
Rob
Cheers,
Rob
