NRS Comutator clearance of clutch fingers
Posted: Thu Feb 19, 2026 6:12 pm
by JvanMaanen
is an almost touching clearance of the comutator terminal ( #4 cylinder) to the high speed clutch finger when engaged normal on the NRS. Mine seems like it could hit if there is any movement in the engine/transmission assembly. This is closest at top dead center. Shimming between engine and transmission would give more clearance.
thanks Jim
Re: NRS Comutator clearance of clutch fingers
Posted: Fri Feb 20, 2026 9:28 am
Is the terminal bolt maybe a bit too long? Protruding from the thumb nut more than necessary?
Posted: Fri Feb 20, 2026 11:16 am
by JvanMaanen
Thanks Jerry, the bolts are all the same length and don't protrude from the thumb screws. Of course, I have no idea if the bolts or thumb screws are original. I will double check the timing and also check the thumb screws against those on my 15. there has to be some way I can get a little more clearance.
