SOLD - 1922 Model T Touring "Popeye" For Sale
Cliff Colee
First Name: Clifton
Last Name: Colee
* REQUIRED* Type and Year of Model Ts owned: 1923 Touring (Popeye)
MTFCA Number: 32142
Post by Cliff Colee » Wed Mar 08, 2023 3:26 pm
1922 Touring for sale. Titled as a 1922 based on engine number, but it has a one-man top so I believe the car dates to late 1922 as model years changed.
The car is in great shape but hasn't run for several years. Stored in a closed garage. I installed floating hubs from Birdhaven along with new driveshaft and new axles when I rebuilt the rear end - but new owner might want to check the rear end for safety's sake to ensure the work was done correctly (I am a shade-tree mechanic...). It has a large-drum Ruckstell rear axle. There is a "belly band" under the motor.
The car has no magnets on the flywheel, but has oil slingers. It runs a distributor and has an Optima Red-Top battery. For safety in the garage I installed a master cutoff switch which completely isolates the battery. It has a Fun Projects voltage regulator. I have the front and rear bumper irons. Five new tires were installed when I got the car, they have been driven less than 100 miles.
The interior upholstry is perfect and the top was only recently installed. Both front and rear floormats are present.
The car's name is Popeye - you can see why if you look at the headlights. I have never seen another car with those headlight lenses. They are one-of-a-kind. The car came to me from Royce Peterson.
This car will run and run well, but it has set in the garage unmoved for almost three years. It will require a fuel tank and carburetor clean out.
The car is located in Fairfax County, Virginia.
Text or call my cell number: 7-oh-three-four-7-7-five-two-9-4.
Asking $8,500 - or make me an offer I cant refuse...
Cliff Colee
First Name: Clifton
Last Name: Colee
MTFCA Number: 32142
Re: 1922 Model T Touring "Popeye" For Sale
Post by Cliff Colee » Thu Mar 09, 2023 2:50 pm
More Photos:
Cliff Colee
First Name: Clifton
Last Name: Colee
MTFCA Number: 32142
Post by Cliff Colee » Thu Mar 09, 2023 3:10 pm
More Photos
Cliff Colee
First Name: Clifton
Last Name: Colee
MTFCA Number: 32142
Post by Cliff Colee » Thu Mar 09, 2023 3:12 pm
Very happy to answer any questions. I am selling due to back problems. Since I cannot use the car as I'd like, it's preferable to pass it along to the next caretaker.
Cliff Colee
First Name: Clifton
Last Name: Colee
MTFCA Number: 32142
Post by Cliff Colee » Sat Mar 11, 2023 11:46 am
Closeup of the headlights - from which came its name: Popeye
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Post by TWrenn » Sun Mar 12, 2023 9:57 am
Those headlights crack me up! Reminds me of that thyroid disease that makes your eyes bulge!! :lol: :lol:
Afraid if I had that car they'd be gone!! No offense to the seller, please. Just an opinion.
JohnM
Last Name: Michaelree
MTFCA Number: 50389
Board Member Since: 2010
Post by JohnM » Sun Mar 12, 2023 10:33 am
It has "Marty Feldman eyes" :D
JohnM
MTFCA Number: 50389
Post by JohnM » Sun Mar 12, 2023 10:48 am
Seriously though, those lenses would act as side lights and help you to be seen from the side. A great option not reflected in the price! :)
MTFCA Number: 51486
Post by TXGOAT2 » Sun Mar 12, 2023 12:51 pm
If a person had one of those Wheelie T parade cars, a set of lenses similar to those could be made up and equipped with hinged, weighted "pupils" that would appear to look downward as the front of the car lifted. Ping pong balls painted black would do for "pupils". The effect would be visible from the front and sides.
Post by Norman Kling » Wed Mar 15, 2023 12:42 pm
It looks like it would be a good driver and looks original enough that most people except some very particular Model T owners would not know the difference. It would be fun for tours, parades, and other events except for shows which award the most original and cleanest car. It has more to offer than the first T I bought. But after fixing some bugs I got mine running well and went on many long tours with it. Only once on a tour was I on a trouble truck and at the next stop, I fixed the problem which was a loose wire in the ignition system, so took it off the trailer and drove it the rest of the way. You might get lucky with the gas if you drain the tank completely and clean out the sediment bulb and screen. Then clean up the carburetor and it might run just fine.
Cliff Colee
First Name: Clifton
Last Name: Colee
MTFCA Number: 32142
Post by Cliff Colee » Sun Mar 19, 2023 9:56 pm
These are the Floating Hubs I installed:
FreighTer Jim
Last Name: Jarzabek
MTFCA Number: 29562
MTFCI Number: 24398
Board Member Since: 2008
Post by FreighTer Jim » Tue Mar 21, 2023 10:34 am
Hi Cliff,
Could you please measure the actual
height from level grade with the top up ?
Thanks,
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
Cliff Colee
First Name: Clifton
Last Name: Colee
MTFCA Number: 32142
Post by Cliff Colee » Wed Mar 22, 2023 4:10 pm
Measurements:
Height: 78"
Width: 66"
Length (bumper to bumper): 146"
Cliff Colee
First Name: Clifton
Last Name: Colee
MTFCA Number: 32142
Post by Cliff Colee » Wed Mar 22, 2023 4:15 pm
Measurements:
Height: 78"
Width: 66"
FreighTer Jim
Last Name: Jarzabek
MTFCA Number: 29562
MTFCI Number: 24398
Post by FreighTer Jim » Mon Apr 17, 2023 5:37 pm
Delivered
FJ
