Looking, for my 1927 Touring,
Differential case
Ring gear and Pinion
Spider
Spider gears
Axle
Axle gears
Pinion bearing
spool
Driveshaft
Break hub cam, left and right
Rocky Mountain Break, lining
WTB: Differential case, gears, axles and other stuff
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: WTB: Differential case, gears, axles and other stuff
Do you not have any "knowledgeable" Model T guys (or gals) nearby to verify you actually need everything on your "parts wanted" list ? Some parts are available new which prevents purchasing "used" parts that are beyond serviceable limits.
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
Bruce, I have some in my collection of parts, no RockY stuff!
- First Name: Melba
- Last Name: Nolan
- * REQUIRED* Type and Year of Model Ts owned: 23 roadster
I also have some but no rocky stuff if Joe doesn't have it all.
I have some stuff from Krull Estate
Differential case
Ring gear and Pinion several sets
Axle gears just 1 very nice looks NOS and another used
Pinion bearing spool many (free) and one that adjustable missing the rear bearing and lshaft lock
Break hub cam, left and right have both think 1 set is original NOS from Chaffins
Can send photos
Differential case
Can send photos
Pictures sent via email
