NOS AIR
Topic author - Posts: 1419
- First Name: Ed
- Last Name: Martin
NOS AIR
I have a limited quantity of 1920s era correct air for sale. I had an old tube that I removed from a petrified tire, and it was still full of air. The tire was stored since the late 20s. The tube unfortunately started to leak once removed, so I decided to run around and capture the vintage air in some small mason jars. It is a must for that correct restoration, and also to silence the annoying purists at the next show. Air removal from the jar the responsibility of buyer. 20.00 per jar plus shipping.
- First Name: Bruce
- Last Name: Compton
- * REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Re: NOS AIR
Great idea ED. I am thinking of marketing genuine Canadian spring water for Model Ts as apparently "spring water never freezes", so you can use it all winter and save buying anti-freeze. Shipping might be an issue though........
- First Name: Joe
- Last Name: Kowalczyk
- MTFCA Number: 49558
Re: NOS AIR
Ed, that’s fantastic, bring over two jars as I have two low tires on my 23 touring.
Regards,
Re: NOS AIR
How much is shipping?
NH Full Flow Float Valves
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
Re: NOS AIR
LOL!
A long time ago, I saw an interview with someone who had visited White Sands, NM and brought some of the sand home with them in a jar.
They said that the ranger told them that the sands were expanding and they said they had proof because they had to dump some of the sand out of the jar every few years, otherwise it would break from the expanding sand.
Re: NOS AIR
I believe that is a modern jar full of NORS air
This is the period correct NOS
- First Name: Jeremy
- Last Name: Donavich
- * REQUIRED* Type and Year of Model Ts owned: 1924 T Fordor
- Board Member Since: 2023
Re: NOS AIR
ROTFL. Brilliant business idea!
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
Re: NOS AIR
My tire is only 2 lbs low. How much per lb ? I dont think I need a full jar.
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
Re: NOS AIR
Hi Ed, I’ll take ten jars. I’m mailing you a check for over the amount. Please forward the balance to my shipper…
- MTFCA Number: 51486
Re: NOS AIR
Anyone remember "Pink Air"?
- First Name: Dennis
- Last Name: Prince
- MTFCA Number: 22802
Re: NOS AIR
I run OE dirt on my car , it is hard to get but worth the effort.
Re: NOS AIR
You guys need to be very careful of this opportunity. You should be aware that under the beliefs of homoeopaths, all the air on Earth contai s traces of that air that was present in the 1920's. You are wasting money just to get a more concentrated version.
- MTFCA Number: 24868
Re: NOS AIR
Do you have any plans to offer NOS 1920's water? My T only cools well with original water.
- First Name: jay
- Last Name: bolante
- * REQUIRED* Type and Year of Model Ts owned: 1922 Runabout
- MTFCA Number: 31221
Re: NOS AIR
I have 17 gallons of used non-detergent oil for sale. Very thick and very black. 2 cents per gallon. Shipped in 1 gallon Ziplock bags only. Can be safely delivered by steam boat.
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
- MTFCA Number: 51596
Re: NOS AIR
How about some NOS smoke, captured as it escaped from original Model T wire harness just before the electrical system failed. Obvious that if the smoke was reinstalled carefully, the electric system would work again. A similar product has been marketed by Lucas suppliers for use in the dreaded "Prince of Darkness" systems used in vintage British cars. That product probably wouldn't work in Model T's as it is for 12 v systems.
- MTFCA Number: 1219
Re: NOS AIR
I only have one of each. For the serious restoration only. Taking bids now.
- First Name: Sean
- Last Name: Butler
- MTFCA Number: 31557
Re: NOS AIR
Back in 1980 after Mt. St. Helens blew, you could buy small vials of ash in the tourist shops. Or... you could scoop it up by the shovel full in the parking lot of the same shop
Sean Butler
Huntington Beach, CA
- Last Name: Tannehill
- MTFCA Number: 49460
Re: NOS AIR
Ed do you know if the air is from a tire with the red tube or the black tube? I have original white smoothies and I don’t want them to turn yellowish. As you can see on the profile picture I bought some original air from another vendor and it started to yellow my tires. I ordered some tire paint to paint them white again, which was expensive, the maker was Barn or Barns white paint based on the label.
- First Name: Ray
- Last Name: Bower
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT
Re: NOS AIR
If you have period-correct scotch, I am a buyer.
- First Name: craig
- Last Name: leach
- MTFCA Number: 26647
Re: NOS AIR
I told a friend about your add. ( he's into antique British motorcycles ) He wants to know if you have any period correct British air? He already
has Lucus & Miller smoke. ( Lucas prince of darkness & Miller king of darkness ) I heard once that Lucas had the contract for the electronics
for the space shuttle. Do you supose if there was a question about the electrics they had to do a space walk & wave their hand in front of the
headlight to check? I asked a British gentaleman one day if it was true that the British drank warm beer because they had Lucas refrigerators
He asked how that taxation with representation was working out for us.
- Last Name: Bruto
- * REQUIRED* Type and Year of Model Ts owned: 1914 speedster 1927 coupe
- MTFCA Number: 0
Re: NOS AIR
Ever seen the Lucas vacuum cleaner? ................It's the only thing they made that didn't suck!
- Last Name: Wilson
Re: NOS AIR
Lucas user manual instruction "Be home before dark"
- First Name: craig
- Last Name: leach
Re: NOS AIR
Lucas gets a bad rap but they invented the four posision switch ON, OFF, INTERMITENT & DEAD SHORT which gave us the intermitent windshield
wiper.
wiper.
- First Name: Jim
- Last Name: Lukash
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring
- MTFCA Number: 390
- MTFCI Number: 207
- Board Member Since: 2009
Re: NOS AIR
I had a jar of NOS air at my space in Bakersfield and Tulare, never even got a question much less an offer.
(I am not smart enough to post a photo, or I would)
So the present value of NOS air is $0.00, based on market research
