WTB - Fender bracket speedster headlight mounts for fenderless speedster
Tom Stephens
Last Name: Stephens
* REQUIRED* Type and Year of Model Ts owned: Parts to build a Speedster
Post by Tom Stephens » Tue Oct 01, 2024 5:34 pm
WTB - Fender bracket speedster headlight mounts for fender-less speedster
Tom Stephens
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: WTB - Fender bracket speedster headlight mounts for fenderless speedster
Post by Kevin Pharis » Tue Oct 01, 2024 6:28 pm
Most use cut off fender brackets, what mounting style…? Early D shaped mount for gas headlight forks? Black car era V notch?
Tom Stephens
Last Name: Stephens
Post by Tom Stephens » Tue Oct 01, 2024 8:29 pm
Whoops, thanks for clarification :-)
'25 speedster, so yes, the later style. I've seen the cut-off '26-'27 fender irons
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue Oct 01, 2024 9:23 pm
I’ll see what I have layin around
Tom Stephens
Last Name: Stephens
Post by Tom Stephens » Tue Oct 01, 2024 11:49 pm
Great, that will work!!
* REQUIRED* Type and Year of Model Ts owned: Speedsters (1919 w 1926), 1926
MTFCA Number: 51415
Post by TRDxB2 » Wed Oct 02, 2024 11:29 am
You might want to match your headlight post's threaded end to the fender iron mount hole for it (no assumptions) .
In addition the 22-25 stop is slight taper
22-25 taper.png (44.49 KiB) Viewed 428 times
Tom Stephens
Last Name: Stephens
Post by Tom Stephens » Wed Oct 02, 2024 10:20 pm
Great info!! I am picking up my headlight buckets on October 7th, so will inspect then and report back on the 8th.
Tom
Tom Stephens
Last Name: Stephens
Post by Tom Stephens » Fri Oct 11, 2024 9:10 pm
My buckets...
Funny, looks like I have one '15 - '17 and one '22 - '25. How will they both fit the cut-off '26-'27 fender irons?
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Fri Oct 11, 2024 9:33 pm
Neither one will fit '26-27 fender brackets. Those later Model Ts have a completely different method of mounting the fender to the frame and the headlights mount to the fenders.
Can you post a picture of the front corner ( either side) of your frame so we can see what you are working with?
MTFCA Number: 51415
Post by TRDxB2 » Fri Oct 11, 2024 11:35 pm
You are correct but Tom made an improper reference as having seen "cut-off '26-'27 fender irons". Tom is building a fenderless speedster so 26-27 irons & fenders are out of scope.
Given what irons he has. Just needs to buy one of each fender iron.. Its a speedster so the mismatch doesn't matter. Or its what a speedster is about, making one from available parts!
It is also possible to make one of headlight posts fit the other style fender iron with a bit of effort
front fender irons 2.png (239.54 KiB) Viewed 135 times
