1912 Front Hub How Do I Remove The Rac?
Bill Everett
Topic author - Posts: 315
- First Name: Bill
- Last Name: Everett
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1914 Touring, 1912 Roadster PickUp in process
- Board Member Since: 2011
How do I remove the race seen in the picture? Ny help woold be great!
Re: 1912 Front Hub How Do I Remove The Rac?
Grind a bar/plate to fit in the race about 1/2 way down. Weld onto the race with a wire welder.
Tap it out against the welded plate/bar with a rod/pipe from the opposite side.
Don ellis
- First Name: Don
- Last Name: Ellis
put a couple of welds on it with the wire welder and it will fall out
Mike Silbert
- First Name: Mike
- Last Name: Silbert
I second welding in a bar, works great, used it multiple times to remove something stuck like that.
It never fights after that unless it is defective already.
Loftfield
- First Name: Thomas
- Last Name: Loftfield
No welder? Use rotary carbide rasp to cut into the race, tap with hammer to loosen race. If no success use a bigger hammer.
