Front plate oil and side drive magneto setup F/S
Topic author - Posts: 1498
- First Name: Layden
- Last Name: Butler
Timing gear cover for oil pump from 1970's era and new reproduction casting for water pump with magneto on the side of a Model T Ford racing engine, you would adapt a 4 cylinder Dodge water pump and complete the machine work $575. New reproduction bronze Dodge water pump $500. Happy to answer any questions. Packaging and domestic shipping included.
- First Name: Mike
- Last Name: Penserini
- * REQUIRED* Type and Year of Model Ts owned: 27 roadster pickup, brass speedster, Mercury # 253 B, Mercury # 1070, Faultless "Hoosier" parts collection.
Re: Front plate oil and side drive magneto setup F/S
Thought I would mention that the Kirk front cover is designed to use a common Dodge / Chrysler flathead 6 oil pump.
- Last Name: Butler
- Last Name: Butler
Anyone building a real go fast?
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
If I did not already have, it would be gone in a New York minute!
- Last Name: Young
- * REQUIRED* Type and Year of Model Ts owned: '26 Tudor, '22 speedster, ABC/Rajo
Can you explain the machining needed for the water pump and which 4 cylinder Dodge pump is needed?
