Shortened driveshaft , driveshaft tube, and rear radius rods
Topic author - Posts: 1063
- First Name: Terry
- Last Name: Woods
- MTFCI Number: 20180
WTB: Anyone have a 12" shortened driveshaft and driveshaft tube suitable for installing a Warford in a late T (27). I think 12" shorter is what is needed. Could ude a pair of shortened rear radius rods for a 26-27, also. Alternatively, I'll have to have mine shortened.
- First Name: DAN
- Last Name: MCEACHERN
Re: Shortened driveshaft , driveshaft tube, and rear radius rods
I have a shortened drive, tube and radius rods. I will check the length. Is this for an aluminum Warford or a cast iron one with the front u-joint?
- First Name: Terry
- Last Name: Woods
Aluminum, Dan. Thanks for checking.
- First Name: DAN
Terry- the drive shaft looks to be shortened 16½", so it won't work for your Warford. Too bad- it has radius rods as well. Perhaps someone else can use it. Dan
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1925 Model T Speedster, 1922 Model t Speedster project
Dan would the shortened drive shaft you have work on a Chicago transmission?
Tim
Tim
- First Name: DAN
Tim- no, a Chicago is about the same length as an aluminum Warford. I can measure a Chicago and report back.
- First Name: Terry
- Last Name: Woods
Anyone else have a 12" shortened driveshaft , tube, and rear radius rods?
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
I can modify yours as I am out of cores, for $325.00 plus all shipping cost.
- Last Name: Rodell
- MTFCA Number: 14035
- MTFCI Number: 13594
Birdhaven bought the Texas T Parts business and is a dealer for the Layne K.C. Warford. They sell new driveshafts which are 12" shorter and offer the service of shortening the driveshaft housing for their transmission purchasers. You could check with them.
- First Name: Terry
- Last Name: Woods
There's a machine shop down here in Texas close enough to me to avoid shipping costs, but I was just hoping someone had what I needed, extra to their needs and cheaper than the machine shop.
