WTB 22 suicide door window parts
Topic author - Posts: 23
- First Name: Galen
- Last Name: West
- * REQUIRED* Type and Year of Model Ts owned: 14 touring, 06 model N, 15 roadster, 18 centerdoor, 22 coupe, 23 chassis, 25 touring, 26 cut off, 26 coupe
My coupe body number on the sill reads :seattle B 4521 The window parts that I need are passenger side thumb and rod elevator shaft, channel at bottom that holds the glass, metal side trim with the notches and the surrounding window trim. I have two sets for the driver side.Any help would be greatly appreciated.Thanks
- First Name: Dennis
- Last Name: Seth
Re: WTB 22 suicide door window parts
Galen,
Are these the parts you are looking for?
I will not be able to get to my shop and look to see if I even have them for at least two weeks. Perhaps someone else may have them.
- First Name: Galen
- Last Name: West
Hi Denny,, Thank you for your reply. Yes, those are the parts that I need. My phone number is 541 540 2596. I would like to speak to you about these parts. Thank you. Galen
