Model T Ford parts for sale - free list available
Post parts for sale here
BenLefebre
First Name: Reuben
Last Name: Lefebre
Post by BenLefebre » Sat Feb 02, 2019 3:30 pm
I have lots of Model T parts, tools, Speedometer parts, 26-27T bat horn w/bkt. Klaxon top & rear push plunger type horns. Stewart top push, Sparton & Ames Model A Ford horns. Hutchins . Horns have been redone. T battery horn covers High & low. #2 Early Model T tire pump Brass & Black ,all redone.#3 original nice chromed/nickeled rad cap -good threads. #4 Jno.W.Brown Brass & Black early teens #115 tail lamp with steel chimney cap #115 ,3 color lenses, burner inside. #5 Oil lamp burner for early T & others, has some stress cracks ,but can hardly see them . #6 E&J oil lamp font 1916-1927 for side & tail lamps .E&J and #'s stamped on bottom. Real nice one. #10 Mod T Left front spring perch 1919-27 (T3819B ) excellent bushing & threads .#7 Mod T side or tail lamp door w/lite purple lens. Has a tiny chip out inside just above the hinge, inner door spring just needs spot solder or braze in place ,so door will latch. #11 Original Model T script pair of lite purple H head lite lenses - one has a small chip on lower end ,which you wouldn't see once the lens is installed .#16 Early Model T right spindle arm w/tapered hole for Speedo drive support "L" bkt. w/new bushing & nut. #19 Model T & TT high bat horn cover 19-25 super nice .(high), From center down is 1 7/8" . #70 Mod T & TT bat horn cover (low)very nice condition (T6432 ). #21 Horn button & bkt. assembly .super nice ,for cars &TT 1918-27 (T8028X ) .Some 1926-27's used the same bkt. but the button was hat shaped.(they all worked the same). #105 Mod T original mag horn bell w/flange. Very good condition 7 1/4" long, bell is 3 1/2" across. * If you would like my complete list w/part description, and prices ,or photos of any of the items ,just email me benlefebre@juno.com Please no PM's . I can attach the list to your email. Thanks, Ben
