Stromberg & Zenith Carbs, at Chickasha
CamMan
Last Name: Young
Post by CamMan » Tue Mar 10, 2020 10:24 am
I have the carbs pictured at Chickashas space FH6.
2 - Stromberg OF
2 - Stromberg LF
2 other Zenith carbs,
one of the Zeniths is partially restored and includes a 2nd for parts
Mike Lebsack-Iowa
Last Name: Lebsack
Board Member Since: 2008
Re: Stromberg & Zenith Carbs, at Chickasha
Post by Mike Lebsack-Iowa » Tue Mar 10, 2020 6:33 pm
Hi, just sent an email to you.
StanHowe
First Name: Stan
Last Name: Howe
MTFCA Number: 19133
Post by StanHowe » Tue Mar 10, 2020 9:30 pm
I sent an email this morning but no response. stanhowemt@aol.com
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Fri Mar 13, 2020 11:55 pm
Sent email on Zenith. No reply. modeltwoods@yahoo.com
CamMan
Last Name: Young
Post by CamMan » Mon Mar 16, 2020 10:51 am
The larger Zenith (left, top) is an HP5A.
Martin
First Name: Martin
Last Name: Cobb
Post by Martin » Mon Mar 16, 2020 4:00 pm
I'm looking for a rebuild kit or gaskets for a Stromberg SF-3 carb. Can you help?
Martin
StanHowe
First Name: Stan
Last Name: Howe
MTFCA Number: 19133
Post by StanHowe » Mon Mar 16, 2020 4:51 pm
Sent you an email, Larry. Thanks
CamMan
Last Name: Young
Post by CamMan » Fri Mar 20, 2020 6:34 pm
The Stromberg OFs and the Zenith HP5A are sold. The Stromberg LFs and the other Zenith are still available. Here is a better photo of the Zenith, together with parts. It is painted in a good 2 part paint that should stand up to gasoline. These carbs have a pot metal venturi. It is intact but cracked. The body is good. As you can see, the body on the parts carb is cracked. I will let it go for the first reasonable offer. I'd like to get $150 each for the LFs.
StanHowe
First Name: Stan
Last Name: Howe
MTFCA Number: 19133
Post by StanHowe » Fri Mar 20, 2020 8:25 pm
If you take a punch and tap the venturi where is shows through the hole it will probably collapse pretty easily. If not, it easily presses out the front opening. It is virtually a no-lathe-skills project to make a venturi out of Aluminum for them. The little screw just ahead of the open hole holds it in. Good project if you are ready to move on past NH's and Kingston L's.
They actually run quite well.
StanHowe
First Name: Stan
Last Name: Howe
MTFCA Number: 19133
Larry, I sent you money today. Thanks, Stan Howe
