Stromberg & Zenith Carbs, at Chickasha
Posted: Tue Mar 10, 2020 10:24 am
by CamMan
I have the carbs pictured at Chickashas space FH6.
2 - Stromberg OF
2 - Stromberg LF
2 other Zenith carbs,
one of the Zeniths is partially restored and includes a 2nd for parts
Re: Stromberg & Zenith Carbs, at Chickasha
Posted: Tue Mar 10, 2020 6:33 pm
by Mike Lebsack-Iowa
Hi, just sent an email to you.
Posted: Tue Mar 10, 2020 9:30 pm
by StanHowe
I sent an email this morning but no response.
stanhowemt@aol.com
Posted: Fri Mar 13, 2020 11:55 pm
by ModelTWoods
Sent email on Zenith. No reply.
modeltwoods@yahoo.com
Posted: Mon Mar 16, 2020 10:51 am
by CamMan
The larger Zenith (left, top) is an HP5A.
Posted: Mon Mar 16, 2020 4:00 pm
by Martin
I'm looking for a rebuild kit or gaskets for a Stromberg SF-3 carb. Can you help?
Martin
Posted: Mon Mar 16, 2020 4:51 pm
by StanHowe
Sent you an email, Larry. Thanks
Posted: Fri Mar 20, 2020 6:34 pm
by CamMan
The Stromberg OFs and the Zenith HP5A are sold. The Stromberg LFs and the other Zenith are still available. Here is a better photo of the Zenith, together with parts. It is painted in a good 2 part paint that should stand up to gasoline. These carbs have a pot metal venturi. It is intact but cracked. The body is good. As you can see, the body on the parts carb is cracked. I will let it go for the first reasonable offer. I'd like to get $150 each for the LFs.
Posted: Fri Mar 20, 2020 8:25 pm
by StanHowe
If you take a punch and tap the venturi where is shows through the hole it will probably collapse pretty easily. If not, it easily presses out the front opening. It is virtually a no-lathe-skills project to make a venturi out of Aluminum for them. The little screw just ahead of the open hole holds it in. Good project if you are ready to move on past NH's and Kingston L's.
They actually run quite well.
by StanHowe
Larry, I sent you money today. Thanks, Stan Howe
