Front plate oil and side drive magneto setup F/S
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Mon Jan 27, 2020 6:24 pm
Timing gear cover for oil pump from 1970's era and new reproduction casting for water pump with magneto on the side of a Model T Ford racing engine, you would adapt a 4 cylinder Dodge water pump and complete the machine work $575. New reproduction bronze Dodge water pump $500. Happy to answer any questions. Packaging and domestic shipping included.
Mike Penserini
Last Name: Penserini
Re: Front plate oil and side drive magneto setup F/S
Post by Mike Penserini » Mon Jan 27, 2020 6:43 pm
Thought I would mention that the Kirk front cover is designed to use a common Dodge / Chrysler flathead 6 oil pump.
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Sat Feb 29, 2020 12:59 pm
To The Top!
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Wed Mar 18, 2020 7:50 pm
Anyone building a real go fast?
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Wed Mar 18, 2020 8:59 pm
If I did not already have, it would be gone in a New York minute!
CamMan
Last Name: Young
Post by CamMan » Fri Mar 20, 2020 6:43 pm
Can you explain the machining needed for the water pump and which 4 cylinder Dodge pump is needed?
