OT Model A running board brackets wanted
Topic author - Posts: 33
- Last Name: Manuel
- * REQUIRED* Type and Year of Model Ts owned: 1923 RPU
I am building a Model A Huckster and need a set o running board brackets. John three 3 seven eight 52 11 two five
Re: OT Model A running board brackets wanted
John, there are two styles. The early ones were forged like the T early cars, later ones pressed steel. I presume you need 4 the same.
- Last Name: Manuel
Yes, Allen, the chassis and cowl are '29 so the pressed steel would be correct and I need a set.
- First Name: Dale
- Last Name: Kemmerer
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring 1911 open runabout
I believe 28 and 29 were forged, 30 and 31 pressed steel
