Nuthin' Special needs large drum Rockies... also a ugly straight thru carburator
Topic author - Posts: 79
- First Name: Chris
- Last Name: Becker
- * REQUIRED* Type and Year of Model Ts owned: 1919 touring, 1917 speedster, 1925 give or take roadster pickup
Guys, I picked up a Warford for Nuthin' Special. I need to piece together a set of large drum rocky mountain brakes for him. Would anyone have a used set or a partial set for cheap so I can put something together. They can be rusty crusty, missing linings bent or missing parts I can fab just about anything needed don't care if parts come from multiple sources .
Also would like to find a ugly looking rebuildable straight thru carb I can rebuild with My son Carston.
Trying to find parts on the cheap for our hot rodded model T that my son Carston and I are building on the cheap. You can see our build threads on the forum from a couple of years ago and last year to see what we have done. hopefully soon we can start chopping the top bows for the top and an aluminum hood for him with Hot Rod louvers as well as a hand brushed blue paint job soon.
Thanks,
Chris and Carston Becker
Thanks,
- First Name: Stan
- Last Name: Howe
- MTFCA Number: 19133
Re: Nuthin' Special needs large drum Rockies... also a ugly straight thru carburator
How old is Carston already?
Seems like he was new just a year or two ago but he actually must be about ten?
- First Name: dick
- Last Name: dock
- * REQUIRED* Type and Year of Model Ts owned: T sprint cars
I was told the other day that you can make your own flow thru Kingston carburetor. Set it up in a mill and bore it straight thru slightly undersized. The take a taper reamer and give the venture a bit of taper for better air flow. Now I have not done this just repeating what an old T guy told me, so don't shoot the messenger.
frontyboy
frontyboy
- First Name: Chris
- Last Name: Becker
Carston is 13 now Stan probably a lot taller then he was when you met him at Portland Swap Meet years ago.
- First Name: Chris
- Last Name: Becker
Is that Kingston L5?
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
OK, For the kid only and no one else (Do not highjack this thread and contact me please), I have a brand new complete set of big drum Rocky Mountain Brakes, $500.00 plus shipping. Will even throw in a modified brake pedal. Email Only.
All the Best,
All the Best,
- First Name: Chris
- Last Name: Becker
hank will send you a message this afternoon thank you very much.
Chris and Carston
Chris and Carston
- First Name: Don
- Last Name: Kirtley
- * REQUIRED* Type and Year of Model Ts owned: 13 and 16 touring, 18 and 20 coup, 20 tudor
- MTFCA Number: 23703
- MTFCI Number: 23153
- Board Member Since: 2009
I have a NH straight thru. you can have It for the shipping. It does need rebuilding. Let me know. Don
