FS MODEL T COIL BOX 1915 with Original One Piece Top
Posted: Tue Mar 24, 2020 12:47 am
Planned to restore this but now have other priorities. The box and top appear to be solid, small dents, no visible pit marks and no rust through. Latches have good snap for locking. The switch is an original one and in very good condition. The contact lever was chipped on the bottom edge and I repaired with JB Weld (it is shaped like an original - note color change). The only thing needed is the wood. $360 shipping included. PayPal preferred.
Original Parts:
Coil Box; One Piece Coil Box Top; Switch (very good condition, minor repair); Un-glazed Tubes (10); Bronze contacts (9); Terminal Bolts: Brass(7) Steel (3); Brass washers (10); Brass Terminal Nuts: Brass (20)
New Parts:
Printed Face Plate; Screws for face plate (3 pieces); Insulating gasket; Water proof cord gasket; Cloth covered wire (3 pieces); Mounting bolt nut set (6 pieces); Insulating washers (20 pieces); Wood mounting screws (7 pieces); Pop rivet set for securing Bronze strip to wood base.
Re: MODEL T COIL BOX 1915 with Original One Piece Top
Posted: Thu Apr 09, 2020 12:48 am
updated price
Posted: Thu Apr 09, 2020 11:55 am
by R.V.Anderson
FWIW, this is an early '15 box, with now reinforcing bead along the bottom edge of the lid.
Posted: Thu Apr 09, 2020 11:56 am
by R.V.Anderson
Typo: NO reinforcing bead, not "now". Sorry.
Posted: Fri Apr 10, 2020 10:50 pm
back to top
