Radiator plates
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Radiator plates
Post by R.V.Anderson » Thu Apr 02, 2020 11:25 am
Still have some of these on hand. $55 stamped with your number; $40 blank. Both postpaid.
The orange-y appearance is from the protective film.
SurveyKing
First Name: Daniel
Last Name: Snell
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
MTFCA Number: 31662
MTFCI Number: 23677
Board Member Since: 2014
Re: Radiator plates
Post by SurveyKing » Fri Apr 03, 2020 11:33 am
Hi RV,
When were these used? As far as the number goes, would that be a serial number or same as car number?
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Re: Radiator plates
Post by R.V.Anderson » Sun Apr 05, 2020 8:27 pm
They were used up into very early 1914, when the radiator upper tank's inside panel was embossed with a pad for the serial number and the plate was dropped. The number apparently was for the radiator only and had no relation to either the car or the engine number.
