Still have some of these on hand. $55 stamped with your number; $40 blank. Both postpaid.
The orange-y appearance is from the protective film.
Radiator plates
Topic author - Posts: 680
- First Name: R.V.
- Last Name: Anderson
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- MTFCA Number: 31662
- MTFCI Number: 23677
- Board Member Since: 2014
Re: Radiator plates
Hi RV,
When were these used? As far as the number goes, would that be a serial number or same as car number?
- First Name: R.V.
Re: Radiator plates
They were used up into very early 1914, when the radiator upper tank's inside panel was embossed with a pad for the serial number and the plate was dropped. The number apparently was for the radiator only and had no relation to either the car or the engine number.
