Holley NH swivel top carburetor
Corey Walker
First Name: Corey
Last Name: Walker
MTFCA Number: 51502
Post by Corey Walker » Tue Apr 07, 2020 1:00 pm
New viton tipped needle and seat, spray nozzle, choke spring and ID plate, reconditioned spray needle, passages cleaned and sealed with set screws, tested float. This one has the larger float for the cowl mounted gasoline tank. Test run. $160 postpaid to continental USA. Email: wlkma9@gmail.com
Mopar_man
Last Name: Govoni
MTFCA Number: 32331
Re: Holley NH swivel top carburetor
Post by Mopar_man » Tue Apr 07, 2020 2:33 pm
What happens if you run one with the smaller float and a 26/7 gas tank?
Corey Walker
First Name: Corey
Last Name: Walker
MTFCA Number: 51502
Post by Corey Walker » Wed Apr 08, 2020 9:47 pm
It works but they started using a slightly larger float because of increased fuel pressure from the cowl mounted tank. I’ve never had a cowl mounted tank, so I say they work, but I figure since they only make the smaller floats and I’ve never heard much discussion about them not working.
Post by Scott_Conger » Thu Apr 09, 2020 10:29 am
Robert
the viton is a more certain seal than the original metal on metal seal (which was very good when new). Smaller float shouldn't be a problem, but it is always a good idea to make use of the sediment bowl shut-off for stops of any length and for sure, storage of the vehicle. Gravity feed systems are 100% fallible. It's just a matter of when and not "if".
NH Full Flow Float Valves
Mopar_man
Last Name: Govoni
MTFCA Number: 32331
Post by Mopar_man » Thu Apr 09, 2020 3:27 pm
Thanks for the info. I rebuilt my sediment bowl as well as got another shut off valve for near the carb.
Corey Walker
First Name: Corey
Last Name: Walker
MTFCA Number: 51502
Post by Corey Walker » Sat Apr 11, 2020 9:13 am
Back to top...
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Sun Apr 12, 2020 11:54 am
Im running two of Corey's NH carbs on my T's. Very satisfied customer here.
RGould1910
Last Name: Gould
Post by RGould1910 » Sun Apr 12, 2020 12:48 pm
I'll buy your carb. Private email sent
markgaynor
Last Name: Gaynor
Post by markgaynor » Mon Apr 13, 2020 5:34 am
New viton tipped needle and seat, spray nozzle, choke spring and ID plate, reconditioned happy wheels spray needle, passages cleaned and sealed with set screws, tested float. This one has the larger float for the cowl mounted gasoline tank. Test run. $160 postpaid to continental USA. Email: wlkma9@gmail.com
Please check your email.
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Thu Apr 30, 2020 11:31 am
SOLD ? ? ?
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Sun May 03, 2020 12:55 pm
Corey, is it sold? / / /
RGould1910
Last Name: Gould
Post by RGould1910 » Tue May 05, 2020 10:20 am
Yes, I purchased it.
