Holley NH swivel top carburetor
Topic author - Posts: 592
- First Name: Corey
- Last Name: Walker
- MTFCA Number: 51502
New viton tipped needle and seat, spray nozzle, choke spring and ID plate, reconditioned spray needle, passages cleaned and sealed with set screws, tested float. This one has the larger float for the cowl mounted gasoline tank. Test run. $160 postpaid to continental USA. Email: wlkma9@gmail.com
- Last Name: Govoni
- MTFCA Number: 32331
Re: Holley NH swivel top carburetor
What happens if you run one with the smaller float and a 26/7 gas tank?
- First Name: Corey
- Last Name: Walker
It works but they started using a slightly larger float because of increased fuel pressure from the cowl mounted tank. I’ve never had a cowl mounted tank, so I say they work, but I figure since they only make the smaller floats and I’ve never heard much discussion about them not working.
Robert
the viton is a more certain seal than the original metal on metal seal (which was very good when new). Smaller float shouldn't be a problem, but it is always a good idea to make use of the sediment bowl shut-off for stops of any length and for sure, storage of the vehicle. Gravity feed systems are 100% fallible. It's just a matter of when and not "if".
NH Full Flow Float Valves
- Last Name: Govoni
Thanks for the info. I rebuilt my sediment bowl as well as got another shut off valve for near the carb.
- First Name: Corey
- Last Name: Walker
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
Im running two of Corey's NH carbs on my T's. Very satisfied customer here.
- Last Name: Gould
I'll buy your carb. Private email sent
- Last Name: Gaynor
Please check your email.Corey Walker wrote: ↑Tue Apr 07, 2020 1:00 pmNew viton tipped needle and seat, spray nozzle, choke spring and ID plate, reconditioned happy wheels spray needle, passages cleaned and sealed with set screws, tested float. This one has the larger float for the cowl mounted gasoline tank. Test run. $160 postpaid to continental USA. Email: wlkma9@gmail.com
- First Name: Terry
- Last Name: Woods
- MTFCI Number: 20180
SOLD ? ? ?
- First Name: Terry
- Last Name: Woods
Corey, is it sold? / / /
- Last Name: Gould
Yes, I purchased it.
