FS Barn Fresh TT Truck
Topic author - Posts: 3332
- Last Name: Chaffin
- MTFCA Number: 31705
I could not get the Classified vehicle section to work, so I will post this here. This is a barn fresh TT truck I rescued from a ranch, located in nearby Hesperia. The engine turns free and compression is good. It has a two speed Ruckstell. The engine is a 1923 (October) with a later improved car transmission cover attached. Wheel wood is pretty poor as well as the tires. Would be a great project for someone. Car is located in Lake Elsinore, California. Price is $2,800. Mark Chaffin (951) 805-0928
Re: FS Barn Fresh TT Truck
Forgot to mention, I also have the title (California) for the vehicle.
Price is now $2,700 in present condition. As previously mentioned, engine turns over and has good compression. I suspect it wont take much to get her running (new battery, carburetor rebuilt, clean gas tank, new points and adjust coils, replace some wiring). I plan on doing the work in the next couple of weeks. If I do, the asking price will be going up to reflect the cost of doing so. I've received a few calls; however, in all three instances "the wife" said no. This is a great project for a minimal investment. If arranging transportation is an issue, I can store it for a few months if that helps. Mark Chaffin (951) 805-0928
The TT has found a new home. Thanks for all the interest. Thanks MTFCA!
