WTB 24/25 Coupe Right Front Fender
Topic author - Posts: 15
- First Name: Bill
- Last Name: Burkhardt
- * REQUIRED* Type and Year of Model Ts owned: 1924 Coupe
- MTFCA Number: 51059
Looking for fenders for a 1924 /1925 Coupe, mainly need the Front right/passenger side fender shipped to Zip 19608
Thanks,
Bill...
Thanks,
Bill...
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
Re: WTB 24/25 Coupe Right Front Fender
Those fenders are different from each other, the 25 uses, they call the commercial fender and the 24 has the passenger car fender on them, so you may need to check to make sure where your body line is at the splash apron. If it follows the apron it is a 24 but if the line goes behind the apron it is a 25. Hope this helps, I went through this a few years ago myself.
- First Name: Don
- Last Name: Cook
- * REQUIRED* Type and Year of Model Ts owned: 1912 1925
Bill, I have two for a 25 (one for each side) that are in pretty decent shape. The problem is that shipping is pretty expensive - I checked out of curiosity a couple of years ago and it was over a hundred dollars to ship both of them. If you want to pay that much in shipping, I would take some pictures for you The price of each would be $60.
Don
Don
- First Name: Bill
Boy I am late to the party here.... guess I need to figure out the notify reply...(found the check box)
Will a 25 work on a 24 other then the body line?
- First Name: Darryl
- Last Name: Bobzin
- * REQUIRED* Type and Year of Model Ts owned: 2, '25 T Runabouts, '14 Touring
- MTFCA Number: 27211
The '23- '25 fenders are the same shape, and bolt holes are the same. As has been stated before the correct '25 fender has a single bead that follows the shape of the fender, and continues under the splash apron. This is sometimes called a commercial fender because it was used on TT trucks through '27. The '23-'24 fender the bead follows the shape of the splash apron, and has a short bead at the edge of the fender, under the apron. So if you are replacing just one fender, you may want to look for the match to the other side, weather it is year correct or not. Posting a photo of the fender you want to match would be helpful.
- First Name: Bill
Well I would like to keep the car as correct as possible, if I go by the title the T was built in 8/24, no way to verify as engine is a 26 with no number. But not to get sidetracked on year. Attached is photo's of the fender that was on the car and a fender that was included with the sale.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Let me go and look in the barn tomorrow, there might be a set left.
Hank
Hank
- Last Name: Bobzin
That Left fender is a '25. If Henry cant help you, contact Dan Hatch. He had a couple of rights last fall. PM me and I will give you his e-mail
- First Name: Bill
Great, Thanks guys!
- Last Name: Hatch
- MTFCA Number: 49974
If You just want the right side email me. Still have a few NOS or early take off. Dan
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Mine are rough, sounds like Dan's is the way to go!
Hank
Hank
- First Name: Bill
Thanks, and thanks for you time Hank, will doHenry K. Lee wrote: ↑Thu Jun 11, 2020 6:51 amMine are rough, sounds like Dan's is the way to go!
Hank
