1921 TT Truck Right Front Cross Member Bracket and/or Cross Member
Topic author - Posts: 10
- First Name: Mike
- Last Name: Hayes
I need a right front cross member bracket for my 1921 TT Truck (It was missing from my frame). I will buy the whole cross member if it has the brackets. You guys haven't failed me yet!! I'm almost to the finish line with this restoration mhayes2107@gmail.com Thanks....
- First Name: Charlie
- Last Name: Coleman
Re: 1921 TT Truck Right Front Cross Member Bracket and/or Cross Member
Mike I do believe I have one for you, the cross member is rusted out at the crank bearing.
I should be able to remove it next week sometime. Let me know if you still need it,
Charlie
Charlie
- First Name: Mike
- Last Name: Hayes
Charlie, Thank you so much for responding. Let me check with my mechanic friend who is in California. (We are quarantining in Texas.) He thinks he found my missing one. Can I get back to you tomorrow???
- Last Name: House
- MTFCA Number: 115
OK.... help me out here Mike. “right front crossmember bracket for TT” means two things to me. Either the NOS corner bracket pair pictured below or the bracket pair pictured below onto which the radiator mounts with 2 rivets visible on the front of the crossmember. I compared both pairs with a TT frame and they’re identical.... George...
gwhouse731(at)gmail.com
May your character not be a writing in the sand but an inscription upon the rock.
- First Name: Mike
- Last Name: Hayes
Charlie, thank you for the photographs. My frame is at the sheriffs department aero bureau hangerAnd they are having an emergency right now. Chris, my mechanic friend who has the frame, will call me back. I will get you pictures of the brackets. I really really appreciate this. Being aircraft mechanic you know how precise he can be. The t guys always tell me Just shim it. We can’t do that. I will get back to you today for sure. Thank you so much my phone number is 714-227-1049. If I don’t answer leave a message and I will get right back to you
