3017B timing cover adaptor
Topic author - Posts: 9
- Last Name: Van Cott
I need an adaptor so that I can use my 1914 timing cover on a rebuilt 1920 engine. If you have one that you want to sell please contact me. Thank You, John
- First Name: Adrian
- Last Name: Whiteman
Re: 3017B timing cover adaptor
I guess you could make an adapter from a bity of plate steel ?
- First Name: Andre
- Last Name: Valkenaers
- MTFCA Number: 23792
- MTFCI Number: 19330
Did you try the "Model T Haven" ??
Andre
Belgium
Andre
Belgium
- First Name: Hap
- Last Name: Tucker
- MTFCA Number: 100
Adrian,
He is looking for the casting that Ford used 1919-1921 when the starter/generator blocks were first introduced. Initially the casting that held the generator cost significantly more than the casting that could be used on a non-starter block. For a detailed explanation of cost of 3017 vs 3017 see the posting at: http://www.mtfca.com/discus/messages/118802/153324.html And the photos and info below are from that posting -- Thanks to Corey Walker for posting them.
I agree with Andre that Model T Haven would likely have that part. It doesn't wear out and if the block freezes it doesn't crack that casting. Photos are a little out of order -- I'm still working on getting them in the place I want them. But I need to stop and do the yard.
Good luck with your search and your project.
Respectfully submitted,
Hap l9l5 cut off
Hap l9l5 cut off
- Attachments
- For using a generator
- 3017 timing gear cover 1919-27 Generator block off - two plates front and back.jpg (13.8 KiB) Viewed 1088 times
- Last Name: Hatch
- MTFCA Number: 49974
That is a rare part. Most time they sell for a lot. I have sold every one I have ever got. I can look for another one if you want. Will take a few days. Dan
Hi Hap, glad to hear from you, trust that you and yours are safe.
My thoughts were to build up a part from two sections of plate, bending and welding a curved section to a flat backing. It may need a third bit to bolt to the block. It would be a bit of engineering work, but possibly be a way forward to solve the issue until a genuine part can be found.
Cheers
Adrian
Cheers
Adrian
- First Name: Hap
- Last Name: Tucker
- MTFCA Number: 100
Adrian,
We are doing fine (funny as we get older we don't say we are doing great ... just we are doing fine
My bad, when you said "plate steel" I read "steel plate" and was thinking you meant the "generator block off plate" part number 3017-D in the illustration from the price list of parts. (Lang's photo at: https://www.modeltford.com/item/3017.aspx )
Best to you and yours.
Hap l9l5 cut off
Hap l9l5 cut off
- MTFCA Number: 121
- MTFCI Number: 16310
Try the classified.
- First Name: Andy
- Last Name: Loso
- MTFCA Number: 346
- MTFCI Number: 119
I have one. aloso@q.com
