WTB cast iron high compression head
dhosh
Last Name: Hoshield
MTFCA Number: 24305
Post by dhosh » Mon May 04, 2020 6:58 am
Hello al, I am looking for a high compression head FOR MY high radiator 1925 RPU. Prefer cast iron standard plugs
'24 RPU
Petoskey, Mi
MTFCA Number: 121
MTFCI Number: 16310
Re: WTB cast iron high compression head
Post by Original Smith » Mon May 04, 2020 11:12 am
I could use one too. I don't like the idea of aluminum heads! This one would be for my 1925 pickup too.
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Mon May 04, 2020 11:48 am
I have a Waukeshaw-Ricardo head. It isn't super high compression, but it can be milled .050-.060 for a little more compression, plus the combustion chamber design gives better low end torque. Unfortunately, I am 200 miles from my parts and with the virus threat, I may be another month from going to them.
tman12
First Name: john
Last Name: Willams
MTFCI Number: 20566
Post by tman12 » Mon May 04, 2020 2:57 pm
Hi From Iowa: I have a mint Waukashaw0- Ricardo head. I bought it for a speedster, ran into a Fronti OHV that I have decided to use instead. I would sell for my investment of $600 it is ready to go to a new home. Thanks John
Steve Hughes
Last Name: Hughes
MTFCA Number: 216
MTFCI Number: 23070
Post by Steve Hughes » Mon May 04, 2020 3:04 pm
I believe that the Pruss head is available in cast iron for additional cost.
dhosh
Last Name: Hoshield
MTFCA Number: 24305
Post by dhosh » Mon May 04, 2020 3:08 pm
Unfortunately, not at this time, unless someone has one in stock. :-( I emailed Kevin Prus last night, and he prompt replies early this morning. Due to difficulty getting quality casts, he doesn't done any, and is waiting for a batch of aluminum casts, as well.
'24 RPU
Petoskey, Mi
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Mon May 04, 2020 4:24 pm
I'm not so proud of my Ricardo head as to ask more than what a new aluminum head can be bought for; in fact, I would trade even for a new Z head, or $335.00 plus shipping.
dhosh
Last Name: Hoshield
MTFCA Number: 24305
Post by dhosh » Mon May 04, 2020 5:23 pm
I would be somewhat on the fence on the W/R head.... Plus time would likely be against it, as mine will be readtly for a head and driving be weeks end.
'24 RPU
Petoskey, Mi
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Mon May 04, 2020 11:05 pm
Well, with the limited availability and choice of iron heads (other than stock), I wish you luck finding one before this weekend. If an iron head with more compression than a W-R is the only thing to suit you, you may not be driving this weekend, and the only other choice (assuming you don't luck onto an iron head with more than 5 to 1 compression, might be to mill a stock head, the maximum of .150 and drive with that until your lucky day arrives.
dhosh
Last Name: Hoshield
MTFCA Number: 24305
Post by dhosh » Tue May 05, 2020 7:59 am
I certainly can't argue with any of that. As I am not looking for high-speed I am looking just to flatten out the hills a little bit it is very likely the increased torque all the WR head may be of more benefit to me, anyway. This weekend was a target not an end all requirement. I will just have to see if waiting a month or more is worth it, though. I understand the situation. A couple hundred miles is not chump change to drive to sell a piece of equipment, on a good day! :-)
'24 RPU
Petoskey, Mi
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Tue May 05, 2020 12:59 pm
Kevin did make a run in cast iron in one of his first runs of heads, but as D. Hoshield found out and posted in the post below this one, Kevin hasn't done any more since then.
dhosh
Last Name: Hoshield
MTFCA Number: 24305
Post by dhosh » Wed May 06, 2020 3:03 pm
Terry ....
Could you please give me a ballpark figure for shipping to Petoskey, Michigan 49706, for the head ..... and maybe let me know if/when you have an idea of when you can make it available? Maybe I can slap my head back on and to my pre-season run-ins, in the interim.
Thanks,
Dennis
'24 RPU
Petoskey, Mi
Pops
First Name: David
Last Name: Houston
MTFCA Number: 32227
MTFCI Number: 23901
Post by Pops » Wed May 06, 2020 9:27 pm
Hello Terry; If Dennis decides against the W-R head I have brand NEW "Z" head I bought but did install because the crankshaft broke in that engine first and my other engine already had "Z" head on it. So we might can talk!
regards
David(POPS) H.
PS What is the rated compression on the W-R?
Pops
First Name: David
Last Name: Houston
MTFCA Number: 32227
MTFCI Number: 23901
Post by Pops » Wed May 06, 2020 9:31 pm
I should have said "But Did NOT Install"
POPS
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Thu May 07, 2020 12:04 am
Terry ....
Thanks,
Dennis
Dennis, if you or someone reading this can post the weight of a W-R or a stock high head, I'll give you as close a freight estimate as possible. Also, specifiy whether you prefer Fedex Ground or UPS carrier.
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Thu May 07, 2020 12:26 am
regards
David(POPS) H.
David, according to the MTFCA Tulsa club website, a stock T high head is rated at 3.8-1 ; a W-R head is rated at 4.0-1 ; and a W-R milled .050 yields 4.2-1. Milling a W-R .060, might get you 4.3-1 , but you might have to fly cut or mill just enough off the top of a W-R combustion chamber to insure piston to head clearance.
dhosh
Last Name: Hoshield
MTFCA Number: 24305
Post by dhosh » Thu May 07, 2020 10:07 pm
Terry... I'll weigh my high head tomorrow.... Sorry... I read your post about compression, and went to the Tulsa club's technical pahes... but missed this one about the weight. UPS ground should be fine...
According to this post:
http://www.mtfca.com/discus/messages/11 ... 1281751326
A '26 head is 26 lbs. That should be close enough for a ballpark..
'24 RPU
Petoskey, Mi
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Fri May 08, 2020 11:43 am
Dennis, my local UPS Store estimates approximately $48.70 by UPS Ground for a package 20x6x4 weighing 26 pounds. I may be off on the measurements of the package as I didn't have a head to measure and the 26 pounds doesn't include any extra weight of packaging which should not add much. Anyway, shipping will be at actual UPS rate that I pay. Even if I am off on size and weight, I wouldn't expect shipping to exceed $50.00, if we are close on weight. No extra fees for packaging.
dhosh
Last Name: Hoshield
MTFCA Number: 24305
Post by dhosh » Fri May 08, 2020 1:50 pm
Very good..... I will commit to purchasing, then. Pm me for details... And if you want a deposit or payment in full, now.
Thanks!
'24 RPU
Petoskey, Mi
dhosh
Last Name: Hoshield
MTFCA Number: 24305
Post by dhosh » Tue Jun 30, 2020 12:13 am
Hi, Terry...
Sorry.. I've been off forum for a bit.. bought a darn camper that need some major rebuilding, so ALL my time has been on that. I forgot all about the forum!
Is the head still available? Have you made the trek to get it?
Thanks,
Dennis
'24 RPU
Petoskey, Mi
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Tue Jun 30, 2020 2:19 pm
Dennis, The head is still available, but I haven't made the 300 mile round trip to get it and other parts that other people want. Unfortunately, when Texas stay-at-home restrictions were relaxed (by our Moron Republican Governor) and I was planning to go, the pandemic flared up again very quickly with a vengeance. All the major cities in Texas, particularly Houston, Dallas, San Antonio, and Austin (all in the top 11 biggest cities in America) are near or at hospital capacity. Since I live in the San Antonio metro area and the parts are in the Houston metro area, and with my age and health history, I have no choice but to wait this out. I hate it. I can't even get to the parts that I need for my restoration, but once again, I won't take the chance. If you have a chance to get what you want, elsewhere, go for it. There is a guy in Montana, Bob Washburn, I think, that has a Waukesha head on EBAY, right now.
dhosh
Last Name: Hoshield
MTFCA Number: 24305
Post by dhosh » Tue Jun 30, 2020 11:17 pm
Hi, Terry...
No problem... Didn't want you to think I bailed on you, is all! No rush. When the time comes, if it's not available, I can always put mine back on. Swapping out later is no big deal. You can always send me an email mail, as well...not call. My phone is 2 three 1 eight 38 fifty five eighteen.
We went to Mackinac Island... A historical vacation island... No cars allowed, about 30 miles north of here, last week. The whole island, and all the shops, and ferry boat companies, all got on the same page and enforced social distancing, face masks, limited number of people in the store, ect. Amazing. Virtuallyd EVERYBODY was wearing a mask (except when seated to eat, etc).... And I didn't hear a SINGLE person complain ... Nobody was really inconvenienced. Quite impressive! It can be done!
Be safe! That's the important part!
Dennis
'24 RPU
Petoskey, Mi
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Wed Jul 01, 2020 11:15 am
I put a Giant Power head on my '25 a couple of years ago, and not impressed one bit. Perhaps, it improved performance by 1%.
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Wed Jul 01, 2020 5:15 pm
I had a Simmons head (that I sold a few years ago at Chickasha) whose combustion chamber is almost identical to a Giant. Its combustion chamber was quite a bit smaller than a Waukesha Ricardo, so I'm surprised that the Giant didn't perform better than 1%. W-R heads aren't known to be high compression heads, but only offer better torque because of the chamber design. Still, I wish I'd never sold the Simmons.
dhosh
Last Name: Hoshield
MTFCA Number: 24305
Post by dhosh » Mon Jul 27, 2020 8:45 pm
Interesting.... Lots of variables, I suppose...
'24 RPU
Petoskey, Mi
SurveyKing
First Name: Daniel
Last Name: Snell
MTFCI Number: 23677
Board Member Since: 2014
Post by SurveyKing » Mon Jul 27, 2020 11:23 pm
Hi Dennis,
If you are still looking for a low original head, I have one that I am willing to sell for $160 plus shipping. No visible cracks but did have a repair to the water jacket at the rear of the head long ago. Email me at DanielSnell2@twc.com
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Tue Jul 28, 2020 1:09 am
Dennis, If you're still interested in my W-R head, I have plans to go fetch it and some other parts for other buyers this coming Sunday.
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Wed Aug 05, 2020 12:57 am
Dennis, I posted the above notice. I didn't have your phone number. Went this last Sunday 140 miles, one way to my parts. Did not hear from you, so didn't bring back head, Same story for another member wanting exhaust parts. I had his phone number but could never get him to answer. left his parts, too. Maybe you've found another head.
