FS Low Head
tselliott
Last Name: Elliott
FS Low Head
Post by tselliott » Fri May 08, 2020 2:27 am
It has been milled to clean up mounting surface.
The water outlet has been professionally repaired.
$225 plus shipping.
Scott Elliott
971-5O6-94O2
MTFCA Number: 121
MTFCI Number: 16310
Re: FS Low Head
Post by Original Smith » Fri May 08, 2020 10:46 am
I'm looking for one for my '13, that has a clean crisp Ford script. The later ones seem to have gotten not so crisp. Can you post a better photo of that area?
Susanne
First Name: Susanne
Last Name: Rohner
MTFCA Number: 464
Re: FS Low Head
Post by Susanne » Fri May 08, 2020 4:30 pm
My '13 head (1-11-13) has a really rough lettering on it - the Ford script is weak, and the Made in USA lettering has some run-togethers... Not sure if this is characteristic for that run, if the mould box got jostled on the way to being poured, or maybe the master for that mould was getting worn by then...
I've noticed on the underside of this head there's the number "3" stamped between the 2 and 3 cylinder bores... my late '15 block has the number "5" stamped in the same location... I'm wondering if it's a factory "proof mark" to show if they were milled after production or not...
tselliott
Last Name: Elliott
Re: FS Low Head
Post by tselliott » Fri May 08, 2020 10:07 pm
Here is the Ford script
tselliott
Last Name: Elliott
Re: FS Low Head
Post by tselliott » Fri May 22, 2020 2:10 am
Bump to the top
tselliott
Last Name: Elliott
Re: FS Low Head
Post by tselliott » Mon May 25, 2020 2:39 am
$200 plus shipping
