**FOR SALE: STEVEN'S FRONT AXLE FRAME TOOL
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
MTFCA Number: 13833
MTFCI Number: 13353
Post by Jack Putnam, in Ohio » Wed May 13, 2020 10:39 pm
For Sale: Steven"s Front Axle repair tool Frame. Reproduced in cast iron, as the original. It is used to repair the worn king pin holes in the front axle of the Model T. This is the frame only as you will need the reamers and inserts available elsewhere.
$275 plus $15 shipping in the USA. I will accept a check or PayPal at jputnam@wcoil.com . Limited production, USA made.
Last Name: Seth
Re: **FOR SALE: STEVEN'S FRONT AXLE FRAME TOOL
Post by perry kete » Sat May 16, 2020 2:23 pm
Jack,
I received my Stevens Front Axle Frame tool today and it arrived just fine. Very nice looking tool and well made.
Thank you
Denny
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Sat May 16, 2020 3:41 pm
This is a very nice reproduction. I have used mine to save several rare early DB axles. The reamer and tap are available here on the forum. Buy this frame and the reamer and tap and you will probably still have less than the cost of an original with more than likely a set of original worn out tap and reamer. I have no part of this sale, other than I'm a very satisfied buyer. Thanks Jack for making them available.
Post by Scott_Conger » Sat May 16, 2020 5:32 pm
I consider the ownership of this tool almost mandatory for a T owner, particularly if you are a natural introvert and have trouble meeting people. Once it gets out that you own one, you'll have more friends than you can fend off.
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Sat May 16, 2020 8:31 pm
It can even make you an Internet star!!
Junkyard4
First Name: Paul
Last Name: Jacobs
Board Member Since: 2010
Post by Junkyard4 » Tue May 19, 2020 7:52 am
Just got mine, it’s great!!
JacolbEdwards
First Name: Jacolb
Last Name: Edwards
MTFCA Number: 50281
Post by JacolbEdwards » Tue Jun 09, 2020 2:40 pm
Are frames still available
First Name: Jack
Last Name: Putnam
MTFCA Number: 13833
MTFCI Number: 13353
Post by Jack Putnam, in Ohio » Fri Jun 12, 2020 8:25 pm
I still have a few frames available. Unknown when the next batch will be available, the foundry uses a different time schedule than the rest of us.
First Name: Jack
Last Name: Putnam
MTFCA Number: 13833
MTFCI Number: 13353
Post by Jack Putnam, in Ohio » Tue Aug 04, 2020 12:34 pm
I have a couple of frames available now. Next batch unknown as foundries seem to run on railroad time.
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Thu Nov 12, 2020 5:04 am
Back to the top
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Tue Nov 17, 2020 12:31 pm
Back to the top
nsbrassnut
First Name: Jeff
Last Name: Lee
Post by nsbrassnut » Tue Nov 17, 2020 8:33 pm
Hi Jack
Email sent.
Jeff
Nova Scotia
Mike Fortney
Last Name: Fortney
Post by Mike Fortney » Fri Nov 20, 2020 7:06 pm
Jack if you have a axle tool left I’ll take one. Mike Fortney 304 5th Ave East Oskaloosa Iowa 52577 mike19@mediacombb.net. Give me you Address and I’ll send you check Thank you Mile
First Name: Jack
Last Name: Putnam
MTFCA Number: 13833
MTFCI Number: 13353
Post by Jack Putnam, in Ohio » Sat Nov 21, 2020 7:12 pm
Steven's Axle frame tool is presently out of stock. JP
