re-babbitted ball caps ( 4th.main )
Topic author - Posts: 835
- First Name: Gene
- Last Name: French
- MTFCA Number: 15614
- Board Member Since: 2014
Rebabbitted Model T ball caps ( 4th. main) … this is an updated advertisement … due to difficulty in purchasing quantities of ball cap cores I will be requiring that a buyer send a core … the price of ball cap will remain the same ($45.00 plus $15.50 postage in lower 48 states ) … this is a change from old ad's in that I will need a CORE … regarding cores … use some judgement … if you don't want to get that part back ...DON"T send it as a core … while you probably will not get the core you send in … someone will … I will re-Babbitt in groups of 20 pieces to keep my process efficient and cost low … I am able to supply in standard diameter or in undersizes … I cam machine diameters down to 1.500" to fit clutch plates that have been machined for ball bearing ball caps … I typically stock Standard , -.002" , -.005" diameters … please accurately measure the tail shaft and provide that dimension to assure correct fit ...gfrench1953@hotmail.com
always an optimist ...Gene French 970-581-2808 or -
- First Name: Gene
- Last Name: French
Re: re-babbitted ball caps ( 4th.main )
Gentlemen:
should have added my address for the core shipment … Gene French 49519 cr.23 Nunn,Co. 80648
- First Name: Gene
- Last Name: French
to the top again , thanks MTFCA
- First Name: William
- Last Name: Rathert
- * REQUIRED* Type and Year of Model Ts owned: 1909, 1915, 1917, 1926
Mine came back yesterday, fit like a glove! Super job! Thank you Gene.
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
to the top again ...thanks MTFCA
- First Name: Gene
- Last Name: French
