KW Timer Riser gear
First Name: craig
Last Name: leach
MTFCA Number: 26647
KW Timer Riser gear
Post by Craig Leach » Sun May 17, 2020 5:51 pm
Anyone in need of a drive gear for a KW Timer Riser? Looks to be NOS I can't see any sign od wear. $35 plus shipping
KW gear.JPG (15.62 KiB) Viewed 294 times
KW gear 2.jpg (15.37 KiB) Viewed 294 times
Re: KW Timer Riser gear
Post by Scott_Conger » Sun May 17, 2020 10:41 pm
FWIW...I don't know if it will help with your ad, but you might want to change the title to Timer "Elevator", as that is what they were called. Took me a couple of readings, passing the ad, to realize what it was you probably had. I think that's a good price for an oddball part that someone's going to be very happy to get. Good luck.
Grady Puryear
First Name: Grady L
Last Name: Puryear
Post by Grady Puryear » Mon May 18, 2020 9:12 am
Il'l take it, email on the way - Grady Puryear
Grady Puryear
First Name: Grady L
Last Name: Puryear
Post by Grady Puryear » Tue May 19, 2020 11:31 am
Mr. Leach, still no word from you ? Grady Puryear
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Wed May 20, 2020 9:27 pm
Hi Grady,
Never got a email. I emailed you with a phone #
Remember when they said computers would make our lives easyer, elliminate the use of paper and we would all be driving fling cars. And look now they are making cars they woun't let us even drive. what else did they lie to us about?
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Wed May 20, 2020 9:38 pm
Scott,
Thanks for the advice, most MFGs called them elevators. I have a retro Atwater-Kent timer elevator that I put a Stulz distributer on works fantastic.
KW called them a timer riser so I figured if anyone had one thats what they would call it.
