Non starter switch 1919-25
ModelT46
First Name: Darel
Last Name: Leipold
MTFCA Number: 823
MTFCI Number: 953
Post by ModelT46 » Fri May 22, 2020 2:04 pm
a solid unit, but some rust. Key 66 and seems to work nice. Comes with key. used on non starter Model Ts from 1919-25. $8 to ship in box. So it is $48 postpaid.
ModelT46
First Name: Darel
Last Name: Leipold
MTFCA Number: 823
MTFCI Number: 953
Re: Non starter switch 1919-25
Post by ModelT46 » Tue May 26, 2020 4:35 pm
Let us try $38 post paid.
Danny Carstensen
First Name: Danny
Last Name: Carstensen
Board Member Since: 2014
Post by Danny Carstensen » Tue May 26, 2020 7:44 pm
Darel,
will it work with starter?
Dan
Post by TRDxB2 » Tue May 26, 2020 9:24 pm
Starter switches control the source of the voltage and in later models the lights. The purpose of the dimmer is to manage the voltage to the lights. As you can see in this non-starter wiring diagram the ammeter is eliminated. The starter diagram has a wire from the coil to the ammeter and then to the starter and horn switches. Will it work? If the switch works and you wire it correctly (with or without the ammeter) then yes. If the dimmer works then the lights would work too
non-starter disgram.jpg (43.2 KiB) Viewed 46 times
