WTB rear tapered leaf springs for 1911 Open Runabout
Topic author - Posts: 2
- Last Name: Steelman
- MTFCI Number: 11664
I am in need of the top leaf only, but realize I may need to by a set to accomplish that. Please email or PM me if you have a leaf or set available. Thanks Scott
- First Name: Mike
- Last Name: Lebsack
- Board Member Since: 2008
Re: WTB rear tapered leaf springs for 1911 Open Runabout
Scott,
Top spring is not visible when installed so you might consider a non taper more common to leaf. Just an idea.
- First Name: Walter
- Last Name: Higgins
- MTFCA Number: 396
- MTFCI Number: 153
The ends of the top leaf stick out from underneath the crossmember and are visible on both an 8-leaf and the oddball 7-leaf specific to his Open Runabout. The 7-leaf was a different spring, but from what I can tell based on what I have on-hand here the top leaf from an 8 happens to be very similar. If not exact, you may be able to reform and regrind a more common top leaf from an 8-leaf spring to fit. A 7-leaf spring will be difficult to find.
Thanks guys for the advice.
