FS mostly early parts
Topic author - Posts: 1249
- First Name: Kim
- Last Name: Dobbins
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring, 1910 touring, 1913 touring, 1916 couplet, 1924 truck.
- MTFCA Number: 8243
1909-10 rear butterfly fender brackets, cast steel, not welded pieces. Very nice, $400 pair. Very slightly used pit and arm, worn about 20 thousands. $30. Nice brass sediment bulb. Handle turns free. $45. NOS small crank pulley. $50. 1913 side light brackets, $50. Tapered leaf front spring, $250. Cast firewall brackets, $40. 1911-14 pair of headlight forks, $80. 1912-13 front cylinder cover, $75. Set of 4 Mae West spring shackles, some have nice repair work, $185. Front spring mount, $50. Nice cast cam brake lever, $275. 1919 dash switch with key, $50. Original new day timer, new is box,$60. Nice original new day timers, $25 each. 1915 tail light bracket with nut, $45. NOS script water inlet, $30. All plus shipping. Kdmks AT att.net.
- First Name: Kim
- First Name: Kim
- First Name: Kim
Re: FS mostly early parts
Butterfly brackets are sold
- First Name: Kim
Timer in the box is sold.
- First Name: Kim
Headlight forks, timers, ft pulley, ft spring are sold.
- Last Name: Barlow
- * REQUIRED* Type and Year of Model Ts owned: 1921 touring, 1911 under construction
Kim
i will take the sediment bown and the small NOS pulley
Mark
Mark
- First Name: Kim
The front tapered leaf front spring ($145.00) and the front oil pan, front spring mount ($50) and 1913-14 sidelight brackets ($50) are still available, all the other parts are sold.
