cow/bull horn wanted
Topic author - Posts: 147
- Last Name: Hand
- MTFCA Number: 28114
- MTFCI Number: 21834
Looking for a mechanical bull/cow horn. there is one on my new to me pickup but it isn't working has a cable & lever unit to operate it but it does not work, nothing from JC Whitney, Advance, or anything I could find on the Web. I do not want an electric horn!!
- First Name: Jim
- Last Name: Davis
- MTFCA Number: 49832
- MTFCI Number: 24686
Re: cow/bull horn wanted
George. I have a Bull Horn that is cable operated on My 26 touring. The horn is electric and the cable operates the internal switch in the horn. Perhaps the wire going into Your horn broke off ?. If You Goggle Bull Horns there are a bunch of cable operated electric horns available. I have never seen a
non electric Bull Horn, But there could well be some out there ?
Good Luck
Good Luck
- Last Name: Hand
Jim, Well maybe that is the problem, will look closer, looks to have had a stop lamp switch no switch, wires are hanging. Thanks
- First Name: Jim
- Last Name: Davis
Ole Bully
George. If Your horn is like Mine it will wake the dead. Makes a moanful sound like Ole Bully got the family jewels hung up in a electric fence. the electric wire on My horn is on the opposite side of the horn from the control cable connections. the wire goes through a open hole in the housing.
I would use it sparingly as it could startle drivers close to You and cause a un planned reaction.
- Last Name: Hand
Jim, That is it, found wire, but horn is junk, has duct tape over bell portion, bet it was to muffle sound. Thank You, Mike yes It looks like that, going to order replacement, Thank You
Don't buy a cheap plastic one get a good Jubilee Bull Horn. They are on ebay at a lot off different price point, if someone does not come up with one here. I just found one myself after reading this. It had the bell changed and was repainted black. The true ones seem to be red with a curved horn and decal on the front.
https://www.youtube.com/watch?v=tNWbuEYT8ag
https://www.youtube.com/watch?v=Z1UcGdOB034
http://wolo-usa.com/340%20english.pdf
Looks like there are 6 and 12 volt ones, 12 might be more prevalent.
1920 Dodge touring
1920 Dodge touring
- First Name: Jim
- Last Name: Davis
Mystery Solved
George. Glad you found the problem. Like they say "it's the little bugs that eat Your lunch". You might want to consider replacing the bull horn with a different type horn, My understanding is the Bull was not a factory horn but a accessory. and the bat horn both battery and magneto were factory horns, on the model T. Ask Larry Smith He will know.
The popular oooga horn was not a factory model T horn. became standard on the Model A but most people associate it with the model T area. The Bull horn cable can be a real pain and the electric horn button takes up less room on the steering column than another leaver to contend with. My opinion is the bull horn is more of a novelty horn but it will make folks jump out of their skin for sure. But for normal driving I think a second horn either bat horn or oooga is needed and use the bull horn for shows and demonstrations makes a unique sound and You vary the pitch and loudness with the control cable leaver.
Good Luck Jim
Good Luck Jim
- Last Name: Hand
Jim, No, wrong answer, will be buying a replacement Bull Horn, to replace the one I found dead on Stanley. Stanley came with an Ahooga, a Bulb Horn, the Bull Horn and I have added a Cow Bell, and a Hand Plunger Horn. I will be adding a Bermuda Ding-Dong Bell after that. My other 3 T's at home have their Factory Horns, not happening with Stanley!!!
- First Name: Greg
- Last Name: Kuhnash
- MTFCA Number: 28086
- MTFCI Number: 21773
- Board Member Since: 2006
Doesn’t sound much different than the battery horn on 26 -27 T
“I don’t like nice people. I like tough, honest people”. - Woody Hayes
- First Name: David
- Last Name: Stroud
- Board Member Since: 2011
Greg, if you heard one in person, you'd know that it doesn't anything like a T horn, anything else either!
Good luck George! Dave
1925 mostly original coupe.
- First Name: David
- Last Name: Stroud
George, just thought of something. Keep your eyes open at antique stores and flea markets. I've been noticing in the last 20 years or so, they have a lot of "antique" auto parts and related things that we used back in the day.
Dave
