WTB or Trade For Late T Mag Ring Core
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Thu Jun 25, 2020 4:37 pm
Want to buy, OR will trade other parts for a rebuild-able late T magneto ring. R.V. Anderson advises the casting number on this magneto ring is T-4389. Lang's lists the part number for this ring as 3250 F. If ring is rebuilt, or a good usable ring, as is; so much the better; otherwise a rebuild-able core will do. Lang's lists core value on single stack coils as $50.00. leave contact info here, or send private message through this Forum. I could, also, use a good used and usable T flywheel with starter ring gear provision. Condition of ring gear, unimportant. I have ring gears that I can replace if necessary. T. Woods
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: WTB or Trade For Late T Mag Ring Core
Post by Henry K. Lee » Thu Jun 25, 2020 4:43 pm
Terry, You can have one of mine for the postage!
Hank
Do you want me to send it to RV?
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Thu Jun 25, 2020 6:01 pm
Henry, Thanks for the offer and I accept. Does R.V. rebuild them, or do I need to send it to Total Recoil, or send it in as a core to Lang's? Could also use a good usable T flywheel as I added to first post.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Thu Jun 25, 2020 6:27 pm
I will call you later Terry!
Hank
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Thu Jun 25, 2020 8:08 pm
I do rebuild field coils; have done many thousands in nearly 30 years.
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Thu Jun 25, 2020 11:58 pm
Thanks for the info, R. V.
