WTB or Trade For Late T Mag Ring Core
Topic author - Posts: 1063
- First Name: Terry
- Last Name: Woods
- MTFCI Number: 20180
Want to buy, OR will trade other parts for a rebuild-able late T magneto ring. R.V. Anderson advises the casting number on this magneto ring is T-4389. Lang's lists the part number for this ring as 3250 F. If ring is rebuilt, or a good usable ring, as is; so much the better; otherwise a rebuild-able core will do. Lang's lists core value on single stack coils as $50.00. leave contact info here, or send private message through this Forum. I could, also, use a good used and usable T flywheel with starter ring gear provision. Condition of ring gear, unimportant. I have ring gears that I can replace if necessary. T. Woods
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: WTB or Trade For Late T Mag Ring Core
Terry, You can have one of mine for the postage!
Do you want me to send it to RV?
- First Name: Terry
- Last Name: Woods
Henry, Thanks for the offer and I accept. Does R.V. rebuild them, or do I need to send it to Total Recoil, or send it in as a core to Lang's? Could also use a good usable T flywheel as I added to first post.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
I will call you later Terry!
- First Name: R.V.
- Last Name: Anderson
I do rebuild field coils; have done many thousands in nearly 30 years.
- First Name: Terry
- Last Name: Woods
Thanks for the info, R. V.R.V.Anderson wrote: ↑Thu Jun 25, 2020 8:08 pmI do rebuild field coils; have done many thousands in nearly 30 years.
