Fed Boyce Motor Meter & wing cap
ModelT46
First Name: Darel
Last Name: Leipold
MTFCA Number: 823
MTFCI Number: 953
Post by ModelT46 » Wed Jun 24, 2020 4:01 pm
AN ORIGINAL WINGED CAP AND BOYCE MOTOR METER FOR THE Model T Ford. Cap is brass and chrome plated. Meter is original finish. I put the meter in hot water and the red started to show, so it is working. Threads on the cap are worn, but should hold okay. I did not polish the cap or meter, but left them as is with aging finish.$125 boxed and postpaid.
Meter and cap 074.jpg (24.67 KiB) Viewed 434 times
ModelT46
First Name: Darel
Last Name: Leipold
MTFCA Number: 823
MTFCI Number: 953
Re: Fed Boyce Motor Meter & wing cap
Post by ModelT46 » Fri Jun 26, 2020 4:52 pm
nice item, original meter and nice old wigned cap.
ModelT46
First Name: Darel
Last Name: Leipold
MTFCA Number: 823
MTFCI Number: 953
Post by ModelT46 » Sat Jun 27, 2020 1:56 pm
holding unit, will post if available.
Model_T_Family
First Name: Eric
Last Name: Sayer
MTFCA Number: 30962
Board Member Since: 2010
Post by Model_T_Family » Tue Jun 30, 2020 9:31 pm
Interested if comes back up
ModelT46
First Name: Darel
Last Name: Leipold
MTFCA Number: 823
MTFCI Number: 953
Post by ModelT46 » Wed Jul 01, 2020 5:42 pm
THE CAP IS BRASS. THE threads are a bit poor, worn, with the bottom thread cross somewhat, so in a worn neck, it does not want to thread in. The threads could be chased, since brass is malabile. I have one person inn line as well as the above person. will get back here later.
