Model B Ford distributor unit
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Thu Jun 25, 2020 6:56 pm
for sale , Model B Ford distributor unit … this ignition unit will work very well on the model A Ford 4 cyl. cars... I used this on my model A speedster for several years before rebuilding a Mallory single point unit … the model B distributor has automatic advance and makes for a very nice "modern" ignition for the model A … price is $75 plus $15.05 flat rate priority mail postage in lower 48 states … actual postage outside this area or international … Gene French 970-581-2808
Gene_French
First Name: Gene
Last Name: French
Re: Model B Ford distributor unit
Post by Gene_French » Thu Jun 25, 2020 7:16 pm
forgot to mention … this distributor can use the stock model A cap and rotor with the brass "plug wires" or the aftermarket cap and modern plug wires sold by many parts outlets ( including Snyders and NAPA ) … always an optimist Gene French 970-581-2808
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Fri Jun 26, 2020 5:53 pm
model B dist. is sold … thank you John W. and MTFCA
