Help does anyone have a gas tank
Topic author - Posts: 336
- First Name: Charles
- Last Name: Jenkins
- * REQUIRED* Type and Year of Model Ts owned: Coupe
- MTFCA Number: 28066
My car is dead on the water if I can't find a good gas tank great use one or does anybody have a new one that they bought and they didn't use please email me Charles Jenkins 84@ gmail.com
- First Name: Darel
- Last Name: Leipold
- MTFCA Number: 823
- MTFCI Number: 953
Re: Help does anyone have a gas tank
round or oval?
- Last Name: Hatch
- MTFCA Number: 49974
I think Gator told me he had some in stock. Dan
- First Name: Brian
- Last Name: Dowell
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring 26 Runnabout 19 Canadian Touring
- MTFCA Number: 52162
- MTFCI Number: 205
Charlie,
While on Tour in South Dakota I was suffering with sediment plugging the sediment bowl. After cleaning several times and not getting very far before plugging again I thought my tour was over the first day.
I put a magnetic on the bottom (outside) of the tank attracting the rust to the magnetic area.
Solved my problem, I thought temporarily. When I got home I attached a magnet to a 3/8's rod and pushed it inside the tank to the collected rust. Pulled the magnet off the outside of the tank and removed the collected rust. Did this about twice a year for a couple of years.
Still have magnet there, no longer collecting rust, cleaned it right up. Worked
Brian.
Brian.
Life is Good, be nice.
Oval 24 coupe
I'm not familiar with the gator how do you contact them
- MTFCA Number: 52564
Might want to go back and put oval in the title. Just click on the pencil over on the right.
1920 Dodge touring
1920 Dodge touring
- Last Name: Chady
- * REQUIRED* Type and Year of Model Ts owned: 1924 Fordor
I have a rusty internal one. But it held fuel depending on your current situation.
My tank holds gas just fine but it is Rusty in side keep putting rust in the fuel line
- First Name: Ken
- Last Name: Buhler
- MTFCA Number: 49471
- Board Member Since: 2012
Charles,
There are several previous discussions on this subject that may be of good value to you if you care to do your homework. If your tank does not leak, you could be able to get through this. Stan Howe had a contribution as did several others. Toss in the 100 drywall screws BUT count them, create a way to turn it like a dryer drum for as long as you have patience or until you have success. Add enough hand shaking end to end until you fear arthritis or cancer and you may win. I am not a fan of coating the inside of anything that you cannot see or be in control of but others have found satisfaction.
Ken
Ken
Work honestly
Stay true to your word
Get the job done right
- Last Name: Hatch
Look up Renew gas tank sealers. See if one is close to you. Be told they do a good job with a lifetime warranty. Dan
- Last Name: Greger
P.M. sent to jachady. dan g.
- First Name: Craig
- Last Name: Raynor
I used the 100 drywall screw method this worked well with a little tip from an older friend. He suggested using some line and make a cradle to hang the tank from a tree limb in order to help with the arthritis issue . - Craig
