For Sale Model T Ford Generator Tester Drive Gear Adapter
Ron Patterson
First Name: Ronald
Last Name: Patterson
Post by Ron Patterson » Mon Jun 29, 2020 4:15 pm
Building a Model T Ford generator tester? Using this device, you can directly spin your generator under test using the Ford generator drive gear. The shaft size is 5/8 inch with a hex head Allen screw to hold it to the motor shaft. You can directly spin the generator from the Model T generator drive gear instead of having to adapt the drive motor via belt or other non-standard drive methods. I had these manufactured several years ago when I was building a generator spin tester and have one left over. Price $50 plus Priority Mail shipping. Ron Patterson modeltcoils(at) windstream(dot)net.
Re: For Sale Model T Ford Generator Tester Drive Gear Adapter
Post by Scott_Conger » Mon Jun 29, 2020 4:43 pm
email sent
Ron Patterson
First Name: Ronald
Post by Ron Patterson » Tue Jun 30, 2020 9:56 am
The drive gear adapter has been sold.
MTFCA
